Spin Cycle Not Working - Appliances - DIY Chatroom Home Improvement Forum
Old 04-16-2013, 11:18 PM   #1
allison78ca's Avatar
Spin cycle not working
Hey, does anyone know what to look for if the washing machine doesn't spin on spin cycle? I have3 kids and I'm hooped if I can't fix this problem soon! Thanks in advance guys!
allison78ca is offline   Reply With Quote
Old 04-17-2013, 08:25 AM   #2
Amateuralex's Avatar
Rewards Points: 270
It's almost always the lid switch. When you close the door, it pushes on a switch. Those switches can fail or get twitchy. I've had situations where they've acted up, then miraculously started working again. Also, in desperation, you can gently jam something in there to push harder on the switch.
There's lots of instructions online about how to take the case off the machine to get at the switch and repair or replace it. Not ultra easy but not super hard either.
If it is the switch, and you can confirm it by using an object to push on it, I bet a handyman or repairman could repair it for under $100.
Amateuralex is offline   Reply With Quote
Old 04-17-2013, 08:32 AM   #3
biggles's Avatar
probably the lid proof switch check here for other items it could be.. www.repairclinic.com good luck
Old 04-17-2013, 10:38 AM   #4
Thanks guys! I will do that.
Old 04-17-2013, 08:38 PM   #5
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
if not the lid switch post your make and model. There are many other things it can be, but the lid switch would be the first thing to check.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 04-17-2013, 10:55 PM   #6
It's not the lid switch. The agitater doesn't move. I was going to take that centre piece off to see if there was a garment stuck under it but then noticed what looks like black metal or something on the floor under the washer. Something must have died. Like a motor? Anyone have that problem before?
Old 04-18-2013, 06:45 PM   #7
#1 HAWKEYE FAN
I thought you said you had a spin problem? Now you say it won't agitate, which is it? We cant help much if you don't give the needed info.
Old 04-19-2013, 10:06 AM   #8
Household Handyman
Rewards Points: 1,408
A lot of washing machines have the agitator mechanism built in under the agitator. Get you model number and google how it is made/put together. On a lot of these there is a cap on top of the agitator which can be pulled to access a nut. This nut can be removed to remove the agitator with a hard pulling action. Underneath the agitator there is the mechanism which make the agitator, well-agitate. On some models there is a rubber-ish, black colored seal. It's possibel that this seal has dis-integrated and is what you are seeing in the washer. Depending on your machine a new agitator unit and seal may cost you about $35. Now if you do have a spin cycle problem then the likely cause, as stated, would be the switch for the door. Depending on you DIY skills this can be tested by unplugging the washer, raising the top of the washer, accessing the switch, taking the two wires from the switch, taping them together so as to by-pass the switch,re-placing the top, returning power to the washer, and trying the washer again. IF you do this do it carefully.
Old 04-23-2013, 12:40 PM   #9
Well, if it won't spin, and it won't agitate but you can hear the motor, and there are black shavings on the floor underneath, I would suggest the motor to transmission coupling.
On direct drive washers, the motor drives the transmission through a coupler which is usually hard black rubber. The motor one direction agitates, and reverse direction spins. If the coupler is intact usually one of the two functions, agitate or spin will work.
Daniel
FixitDragon is offline   Reply With Quote
Old 04-30-2013, 02:29 PM   #10
Rewards Points: 156
If you are hearing the motor running, but nothing's happening, check these things: Many washers these days use a one-way clutch...The motor spins one way to agitate, and another direction to spin the tub. If the motor is spinning, but the tub is not, it could be a clutch. Older washers, like the pre 80's Whirlpools have a pair of solenoids called a "wig-Wag" that shift the gears in the transmission between spin and agitate. If one of these solenoids are bad, same thing...either spin or agitate goes out. Maytags I think, specifically, have spin belts that don't come into play during agitate. The belts (very similar to the ones on yard tools) are designed to intentionally slip when the motor goes into spin cycle to reduce shock and unbalanced forces on the motor. When these belts get old though, they tend to stretch and slip too much, causing the motor to spin, but never get enough grip to move the tub.
av-geek is offline   Reply With Quote
Old 04-30-2013, 03:53 PM   #11
Rewards Points: 744
Daniel
This was my first guess. Had mine go out last year. It was a 10 minute fix, after getting the part. Repairclinic.com and appliancepartspros.com have great video tutorials, troubleshooting info, and great return policies.
Seattle2k is offline   Reply With Quote
Frigidaire Affinity front loading washer 2006 model-won't spin final spin? imola ghost Appliances 9 10-23-2015 05:23 AM
ge washer walks in spin cycle dianepnut Appliances 0 03-20-2013 05:09 PM
loud washer knocking/banging noise during spin cycle NABRIL Appliances 0 01-14-2013 02:51 PM
Maytag washer agitating during spin cycle. califbev Appliances 0 08-30-2012 04:34 AM
Top load washer won't agitate nuclearjesus Appliances 4 05-30-2010 05:47 PM
