Solid Dryer Vent? - Appliances - DIY Chatroom Home Improvement Forum
Old 05-02-2012, 10:57 AM   #1
Rewards Points: 150
Solid dryer vent?
My current flex line dryer vent has fallen apart. Is it possible to use/make solid vent pipe? Thought I saw it somewhere that they use like HVAC duct? Any tips on materials/process be helpful and appreciated.
MikeVila is offline   Reply With Quote
Old 05-02-2012, 11:08 AM   #2
Rewards Points: 13,950
Whenever possible it's the best way to go. Use Foil tape to seal all the seams, not duct tape.
Old 05-02-2012, 11:12 AM   #3
Rewards Points: 150
What type of material do I need to purchase? Haven't really done to much HVAC work to have grip on what type material to use. I do have some foil tape though already as I do know duct tape isn't for duct work lol.
Old 05-02-2012, 11:21 AM   #4
Post a picture of what you have, no way to tell without seeing it.
Old 05-02-2012, 11:33 AM   #5
Rewards Points: 150
I'd have crawl under house and don't want do that until have fix it lol. It comes straight down them pretty sure it's a simple 90 and runs over where it attaches to current exit out through block.
Old 05-02-2012, 01:23 PM   #6
Rewards Points: 150
I see Lowes has 4" solid pipe and some elbows. Just bend and clip together and screw at connections?
Old 05-02-2012, 01:37 PM   #7
Civil Engineer
Rewards Points: 4,854
I used galvanized duct, 4 inch diameter. Comes in four foot pieces, you cut them to length as needed. I think you can get solid aluminum also, do not use flexible duct, the inside ridges collect lint. Also there are flexible connectors, pretty cool, they bend in three dimensions, and are connected to the duct using band clamps or spring clamps. Do NOT use sheet metal screws, the screw penetrates and catches lint. Use foil tape as previously recommended to seal.
Old 05-02-2012, 01:42 PM   #8
DIY hobbyist
You can use 4" snaplock pipe, do not screw joints only tape or pop rivet. I think code will allow up to 2 hard 90* rest should be 45 or 30 degrees. Dryer could come with specs.
ggold is offline   Reply With Quote
How far to run dryer vent? bigmark77 HVAC 9 12-04-2011 12:08 PM
Problems with inside the wall dryer vent darsunt Appliances 2 11-08-2011 06:58 AM
Vent cap size ok for dryer? chazman113 Roofing/Siding 4 07-27-2010 10:39 PM
Dryer Vent DoubleHumbucker Appliances 3 10-02-2009 01:50 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 04:26 PM
