soggy outlet pipe for dryer?
Spackle should be fine, although, due to the temperature changes that it is subject to, I would use regular drywall mud, which you can buy premixed at most hardware stores and home centers, and which will allow for more expansion and contraction. As mentioned, way too long of a run, but you have already responded to that, so you'll have to make the best of it. I assume that you are using rigid metal vent, if not, change to that, use an absolute minimum of elbows, and use foil duct tape on all of your joints, to ensure that you create the best flow possible.
