Snowblower Won't Start - Appliances - DIY Chatroom Home Improvement Forum
Old 12-10-2010, 01:29 PM   #1
snowblower won't start
would likke to know what would cause a snowblower form starting and if its the fuel line ,how do i check it? changed spark plug,put gas& oil mix ,electric start and it still won't start
sherrymH is offline   Reply With Quote
Old 12-10-2010, 01:32 PM   #2
I'm familiar with the product,and do know some things about its funtion
Old 12-10-2010, 03:52 PM   #3
A Little Of Everything
Rewards Points: 1,364
If it's a 2-cycle - one in which you mix the gas and oil - you almost certainly have a carburettor bowl that's gummed up. The only real way to take care of the problem is to remove the bowl and clean it.
DrHicks is offline   Reply With Quote
Old 12-12-2010, 10:42 PM   #4
Rewards Points: 494
I've had great success with lawnmower and snow blower using starter fluid, especially first start of the season.
It's ether and comes in a spray can. Big box store Walmart carries but any auto parts store will too. I remove spark plug, spray into plug hole for about 3 or 4 seconds and quickly re-install plug by hand, as tight as I can, reconnect wire and (hopefully) start. When running a minute or 2, I shut off and tighten plug with a wrench. If it sputters and starts but sounds like it will stall, hit the primer diaphram to keep gas flowing.
diyorpay is offline   Reply With Quote
Old 12-12-2010, 11:10 PM   #5
Rewards Points: 133
What is the make and model of the snowblower? This will help get more specific information. Trying it with starting fluid as stated will help narrow down the issue. How old is it?
One thing that I have had luck with is B12 Chemtool, which is available at the auto parts store. It comes in a spray and a pour in can. I used the spray to clean out the float bowl and carb, and put some in the gas. It is a fual treatment, and does a good job of removing the gummed up old gas in my 80's vintage snowblower.
jimmyfloyd is offline   Reply With Quote
Old 12-14-2010, 06:11 PM   #6
Rewards Points: 5,336
If the fuel has been left in the tank, even with a fuel stabilizer, it can cause the carburetor needle to malfunction. There are kits to replace these parts.
My service guy recommended dropping the fuel bowl at the end of the season and removing the fuel. It's one nut and 1/4 cup of gas. This way the needle doesn't get fouled up. He also recommended a marine fuel stabilizer(not Stabile) as it was much better. I just pull the bowl.
Ron
Old 12-26-2010, 06:33 AM   #7
Question
trouble starting cub cadet snowblower
this is a single stage blower last used in feb 2010. i tried the electric start and it turns but won't finally turnover. any suggestion on what i should try?
janjon is offline   Reply With Quote
Old 12-26-2010, 07:55 AM   #8
Follow the previous advice above.
Did you leave the gas in the unit?
Did you add fuel stabilizer to the gas?
When was the last time the unit was tuned?
Did you turn on the fuel petcock?
Is there gas in the tank?
Ron
Snowblower Repair FF_Thor General DIY Discussions 0 11-29-2010 03:51 PM
Snowblower won't start!! didi1020 Automotive Repairs 3 12-22-2009 03:43 PM
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Tools 2 08-26-2009 08:26 AM
Brand new PAYNE PG9MAB won't start . Error code 12 tp618 HVAC 3 12-19-2008 09:21 PM
Blue smoke at start up, and shudder at idle fauer Automotive Repairs 6 08-22-2008 11:39 AM
