Smell In The Furnace Room - Appliances - DIY Chatroom Home Improvement Forum
Old 03-25-2013, 10:16 AM   #1
smell in the furnace room
For the past few weeks, have noticed a smell when the furnace turns on. Went down to check the furnace room where we also have the gas hot water heater. It smelled quite a bit like chlorine. Could that be natural gas? Hubby doesn't think so but I do SMELL something.
Shirleys44 is offline   Reply With Quote
Old 03-25-2013, 10:23 AM   #2
Rewards Points: 14,014
Instead of wondering and have it go boom I wold have called the gas company or service person by now.
Funny smell, gas appliances never a good thing.
Old 03-25-2013, 10:29 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 818
Call them. They have a gas sniffer that will detect leaks.
Could it be a sewer smell from a dried out floor drain?
Old 03-25-2013, 10:37 AM   #4
Indentured Servant
I had an odor like that, took the furnace burners out and inspected the heat exchanger. It was clogged with soot. I vacuumed it out, cleaned the burners and the connecting tube out, put it back together and tested it for any blow back or leaks. A crack in the heat exchanger was my fear, but I think that I just had clogged connecting tubes resulting in improper air mixture. Keeping a close eye on it now, plan on upgrading to high efficiency this summer but want to limp this one through the heating season right now.
Do you have city propane or a tank? When tanks get towards empty, they put a chemical in that we can detect an it does smell bad. Get it checked out.
jackpine is offline   Reply With Quote
Laundry room has mildew smell Carole B. Owen Plumbing 3 10-18-2011 07:18 AM
Burning smell from furnace? scottyv81 HVAC 5 01-25-2011 08:49 AM
Insulating furnace room BlueBSH Building & Construction 12 02-27-2010 10:16 PM
exhaust smell when the furnace kicks on puchead77 HVAC 5 01-19-2009 01:11 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
