Small Pressurized Tank Above My Gas Water Heater - Appliances - DIY Chatroom Home Improvement Forum
Old 03-03-2012, 09:24 AM   #1
Small pressurized tank above my gas water heater
This small tank (therm-x-trol) sprung a small pin sized leak. I have the water turned off and this small tank has a schrader valve that I have bled off the pressure with. Is this easy to replace myself?
tcason is offline   Reply With Quote
Old 03-03-2012, 09:35 AM   #2
Rewards Points: 14,290
Nothing to it, unscrew the old one and install a new one.
You do need to check the pressure on the new tank before installing it.
It should be about 2, lb. less then the system pressure.
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
H2OwTo Pressurized Water Tank problems Gary5579 Plumbing 4 12-11-2011 06:25 AM
Hot Water Tank and Pressure Help tbakbradley Plumbing 2 01-17-2011 09:25 AM
Raising Water Heater Tank doesntmatter Plumbing 6 09-30-2010 09:05 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
