Small Appliance Cable Clip Removal - Appliances - DIY Chatroom Home Improvement Forum
Old 01-30-2014, 08:57 AM   #1
Rewards Points: 70
small appliance cable clip removal
Might be too small an issue for this forum, but I am trying to rewire a room humidifier.
I cannot for the life of my figure out how to release the small plastic bit that holds the electrical cable as it passes through the casing.
there must be a trick.
or, is this one of these disposal installs that is melted into place and cannot be removed and reinstalled?
small appliance cable clip removal-img_20140130_085251.jpg   small appliance cable clip removal-img_20140130_085310.jpg
pjstock is offline   Reply With Quote
Old 01-30-2014, 09:51 AM   #2
Rewards Points: 358
Sometimes they can be fussy. There is a release on the top and bottom or on the sides that must be pressed and then pulled at the same time for removal. A pair of needlenose pliers should work.
jmon is offline   Reply With Quote
Old 01-30-2014, 10:00 AM   #3
Rewards Points: 14,312
I prefer a regular pair of plyers so I have more surface area to compress it.
Squeeze and pull, it will pop right out.
Old 01-30-2014, 10:14 AM   #4
Rewards Points: 70
SOlved
tada!
brilliant. thank you.
for the reference of others, this one removed by compressing it (severely) on the outside of the casing and pulling to the outside. (which probably should have been obvious but...)
The Following User Says Thank You to pjstock For This Useful Post:
jmon (01-30-2014)
Old 01-30-2014, 10:18 AM   #5
Rewards Points: 358
Your welcome. Glad it worked for you.
Hot appliance due to jumpering receptacle neutral to ground screw justplumducky Electrical 6 07-09-2013 05:52 AM
Quick small appliance circuit question mgarfield Electrical 3 01-23-2010 12:22 PM
Protecting small run of 8/3 cable in garage tigereye Electrical 4 01-03-2010 10:22 AM
cable in drain machine has small kinks, bad? darsunt Plumbing 1 08-05-2009 11:58 AM
Small condo, appliance cost recommendations Snowy334 Interior Decorating 1 08-12-2008 06:17 PM
