#1 |
simple frig waterline question
I need to replace the waterline going to my refrigerator, but it runs behind several cabinets and the dishwasher. How do I re-run the new waterline through those little holes in the back?
#2 |
Long-Time DIYer
Refrigerator water supply kits have flexible (plastic and copper) tubing that come with them that should be relatively easy to "thread" through cabinet holes.
Turn the water off, disconnect the old line, thread through the new, and hook it up. Depending upon the distance, you may need two kits, because you need enough coiled behind the fridge to pull it out without disconnecting anything. Good Luck! Mike |
#3 |
The hooking up part is no problem, but my actual dilemma is getting the flexible tube through the walls behind the dishwasher. I tried to tape the new tube to the old one and pull it through the holes but it came apart. Any ideas how I can do this without drilling huge holes and trying to straighten the tube and hope I can fit it exactly through the hole on the other side of the dishwasher?
#4 |
Try sticking a straightened-out coathanger into the tube about 12" (or whatever straight length you need) and using that stiffness to keep the tube straight while you fish it down. A "cap" of tap at the end to prevent it from falling out the open end should be all you need.
#5 |
HandyMan Engineer
Another option is to run it a different route. I had a similar problem where the tubing ran under my cabinetry and couldn't see the holes between the seperate cabinet units. Anyway, I ended up going through the floor at the back of the fridge and taking a new root to the sink lines. Works great if you have access in the basement.
#6 |
I would try some stiff but flexible wire to connect the tubing if it is the plastic type and the holes are big enough to allow it. Take a length of this wire, baling wire or stripped down small electrical wire, bend the ends, stick through the plastic all the way and bend down flush or maybe more with the other side. One bend in the old tube and one in the new tube with the old and new butted together. Tape secure and pull through the holes without getting in a hurry. If the holes have any extra space, you might get lucky. Basically just enough tape to keep the butted ends of the tube together. You don't want a long piece of tubing to be stiff.
#7 | |
simple frig waterline questionQuote:
Trying to keep all my fingers and toes To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Display Modes | |
| Basement Renovation Question | KUIPORNG | Remodeling | 234 | 08-26-2008 09:19 AM |
| General easy drywall question | bigboyjoel | Building & Construction | 3 | 05-27-2007 09:52 AM |
| leaking from under frig when frig w/ice maker was moved forward | tzippy | Plumbing | 1 | 11-05-2006 02:22 PM |
| simple question | djcrewz | Electrical | 7 | 10-25-2005 12:01 PM |
