Side By Side Refrigerator Not Working. - Appliances - DIY Chatroom Home Improvement Forum
Old 07-09-2013, 09:15 PM   #1
jburd964's Avatar
Rewards Points: 166
Side by Side Refrigerator Not Working.
Looked it over and can't get compressor to do anything unless I tap on it, then it will hum for a second and quit. It's a MayTag.
Gun control isn't about guns, IT'S ABOUT CONTROL.
jburd964 is offline   Reply With Quote
Old 07-09-2013, 09:37 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
very possible you have a bad relay on the compressor
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 07-09-2013, 09:56 PM   #3
chitownken's Avatar
Rewards Points: 510
Or possibly a bad compressor. How old is the refrigerator?
chitownken is offline   Reply With Quote
Old 07-10-2013, 08:05 AM   #4
jburd964's Avatar
Rewards Points: 166
It's was purchased around 2007. It will work right occasionally. But had to replace it because of loss of food. Want to repair it to try and get some of my money out of it.
Old 07-10-2013, 11:35 AM   #5
chitownken's Avatar
Rewards Points: 510
Check your warranty. Most are 5 years on compressor but some are 10. Might want to look into a start assist kit for your model.
Old 07-28-2013, 08:46 PM   #6
jburd964's Avatar
Rewards Points: 166
I tried ordering a starter kit for compressor and all they had was the capacitor it didn't work. What else would be part of a starter kit?
Old 07-30-2013, 06:47 PM   #7
#1 HAWKEYE FAN
you need the start relay
Old 09-16-2013, 08:01 AM   #8
jburd964's Avatar
Rewards Points: 166
is there anyway to be 100% sure that the compressor is bad.
Old 09-16-2013, 08:14 AM   #9
PoleCat's Avatar
Rewards Points: 1,646
Drill a hole in it. That removes all doubt.
The hum and click you describe sounds like too much current going through the thermal OL. Could be:
  1. Insufficient voltage
  2. Bad windings
  3. Locked up compressor
You can measure voltage and ohm out the windings. If those are good then the compressor has seized.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 09-17-2013, 12:15 PM   #10
jburd964's Avatar
Rewards Points: 166
Tags
refridgerator , refrigerator compressor
coaxil side by side with cat5 telephone wire DiegoJames Electrical 3 06-11-2013 06:53 PM
whirlpool 2004 side by side refrigerator ice maker not working Grethenwsh Appliances 4 04-19-2012 11:20 AM
Durock installation in bath, what side goes out? smcmurrey Building & Construction 8 12-12-2010 07:48 PM
Ceiling mounted clothes rod (one side wall mount, one side ceiling mount) DCA General DIY Discussions 9 08-17-2009 11:13 AM
Side By side refrigerator Susie Q Appliances 6 08-31-2007 04:26 PM
