Side By Side Refrigerator - Appliances - DIY Chatroom Home Improvement Forum
Old 08-31-2007, 01:57 PM   #1
Side By side refrigerator
Hello there. Do hope you can provide me with some info. My side by side is not circulating any air inside. The frig side is warm hear nothing. The freezer side is thawing items out slowly. Frost had built up on the back panel.
Took everything out, and defrosting panel now. Have been told their is a computer board in the frig, to check and see if we can tell what needs replacing. But sounded like it was the fan. Can you tell me how to get to the fan. This side by side looks new. It was here two years ago when we moved in. I take bottom front panel off and clean it often. The back panel not as often, due to a little heavy pulling it out, and men not around.
Is there some way we could order the part on the internet? There is no appliance store in town.
Thanks a mill. Have a marvelous weekend.
Susie Q is offline   Reply With Quote
Old 08-31-2007, 02:08 PM   #2
SuzyQ,
search the makers site on line if schematic drawings can't be found on the unit. Most have a good trouble shooting section.
could be fan / defrost timer / or heater system problem.
Good luck....
Big Bob is offline   Reply With Quote
Old 08-31-2007, 02:36 PM   #3
Side by side
Yes I do think it is the system. The automatic defrost isn't working either. Is this pricy?
Old 08-31-2007, 02:38 PM   #4
Bob where is the schematic drawing located? Behind the panel in freezer?
Old 08-31-2007, 03:03 PM   #5
two common areas they are found is bottom front taped near vent grate or bottom at the rear behind removable panel.
Timer $20 to $35 or more other stuff lots more. consider replace with new unit from a scratch & dent wholesale outfit "sears outlet" if not timer or fan.
Last edited by Big Bob; 08-31-2007 at 03:05 PM. Reason: scratch is not spelled scarthed
Old 08-31-2007, 03:20 PM   #6
side by side
Is the computer board behind the freezer panel?
Old 08-31-2007, 03:26 PM   #7
To properly defrost you will need to remove back panel of freezer.
Did you not find info on makers site?
I would doubt it would be there.
Water line for new refrigerator? pa555 Plumbing 5 06-08-2012 06:06 PM
Noisy Frigidaire side by side EZ Rider Appliances 7 03-12-2008 12:51 PM
