Shocking Alarm Clock - Appliances - DIY Chatroom Home Improvement Forum
Old 04-15-2013, 10:37 AM   #1
Rewards Points: 18
shocking alarm clock
I have a bit of an odd request...
I think I have gotten into the habit of hitting the snooze button on my alarm clock in my sleep. Naturally, being savvy with a soldering iron, my solution is to construct an apparatus to deliver a nonlethal shock to me whenever I try to hit the snooze button. The problem is I'm not sure what the best voltage is to get the job done. Too high and I risk injury/death, too low and there will be no effect. So before I commence with lengthy trial and error, I thought I'd see if anyone had any knowledge in this area.
Ideally I'd like the shock to be sufficient to cause pain, but not so large that the pain is excruciating or risk injury. I had thought to achieve the voltage by putting a number of 6v or 9v batteries in series. I assume battery current will be appropriate, but if not feel free to suggest something else.
Thanks!
Execut1ve is offline   Reply With Quote
Old 04-15-2013, 10:40 AM   #2
Rewards Points: 2,516
Why stop at shocking, might as well put some razor blades around snooze button too.
hammerlane is offline   Reply With Quote
Old 04-15-2013, 10:40 AM   #3
Rewards Points: 18
sir you have entirely missed the point of my post. let me reiterate: I WANT TO AVOID INJURY
Old 04-15-2013, 10:44 AM   #4
In the spirit of cooperation:
Good Morning Sing N Shock alarm clock.
When the user presses the aluminium-coated snooze button on the top of the clock, harmless micro-volts of electric current are emitted to jolt them into life.
Old 04-15-2013, 10:59 AM   #5
bbo
when I was younger and needed extra incentive to get up, I'd just move the alarm clock to the other side of the room, necessitating getting out of bed to shut it off.
bbo is offline   Reply With Quote
The Following 3 Users Say Thank You to bbo For This Useful Post:
Dave Sal (04-15-2013), davido30093 (04-16-2013), r0ckstarr (04-17-2013)
Old 04-15-2013, 11:18 AM   #6
Rewards Points: 18
that is a possibility, but I do not favor it as it would increase the amount of time that the alarm is going off, potentially waking up my wife
Old 04-15-2013, 11:23 AM   #7
bbo
you should also look into other factors to make sure you get a good sleep. less stimulation before bed, quieter/darker sleep area, etc.
on a funny note, a cattle prod for the wife to poke you with should you become lax in your duties to turn off the alarm would be great training and more incentive to jump out of bed.
Old 04-16-2013, 06:20 PM   #8
Rewards Points: 83
If waking up your wife with the alarm is a problem, then your problem is much bigger than anything we can solve here.
Move the clock so that you can't reach the snooze button and your wake up problem is solved. The electric shock solution is silly. Your other problems are for a different forum.
davido30093 is offline   Reply With Quote
The Following User Says Thank You to davido30093 For This Useful Post:
Dave Sal (04-16-2013)
Old 04-17-2013, 04:45 AM   #9
Bill Kearney
Rewards Points: 1,174
Right, so you want to rig up a half-ass way to give yourself a heart attack in the morning. Bad idea.
Consider getting an alarm clock that has a gradual light feature. These work a lot better at waking us, without a snooze. The idea being it brings the light up gradually with some background nature sounds. Then it either turns on the radio or the buzzer. Most of the time the light/background sounds are enough. This is the current model like the one we got a while ago:
http://www.hammacher.com/Product/81819
(ignore the 'aromatherapy' part, it's junk)
wkearney99 is offline   Reply With Quote
Old 04-17-2013, 04:57 AM   #10
r0ckstarr's Avatar
Rewards Points: 2,012
I cannot help you design the clock you want, but I too sometimes have the hardest time waking up in the morning. I've slept right through the alarm many times, even with it sitting 2ft from my head.
I can also understand not wanting to wake someone up. Here's how I use that to my advantage.
I set my alarm clock for the time I want to wake up.
I have a computer across the house in another room. I use a website called Online Clock, and set it to 15mins after my other alarm. Then I turn the speakers full blast.
This means that once my first alarm goes off, I have 15mins to get up and go turn off the other alarm, or face the wrath of my girlfriend for waking her up so early. Fear has not failed me yet.
r0ckstarr is online now   Reply With Quote
Old 04-17-2013, 05:00 AM   #11
Rewards Points: 166
Wouldn't that just mentally condition you to skip the snooze and turn off the alarm completely, potentially leading you to just fall back asleep without being re-awakened in 10 minutes.
If you want to tinker you could just disable the snooze button and get the same effect without the shock.
Are you sure this isn't for a practical joke on someone else?
dftc is offline   Reply With Quote
Old 04-17-2013, 05:29 AM   #12
Yes that is an issue for another forum
Old 04-18-2013, 06:02 PM   #13
Oso954's Avatar
Rewards Points: 1,010
Use a windup Big Ben Alarm clock set out of reach of the bed as the second alarm. Your motivation will be to get up and shut the Big Ben off, before the alarm sounds.
Added Benefit, it still will get you up during a power failure.
Oso954 is offline   Reply With Quote
97 Jetta car alarm - please help - can't start crankbait09 Automotive Repairs 6 02-23-2012 08:30 PM
Temperature in junction box buried under R49 insulation (heat detectors/smoke alarm) darlingm Electrical 2 01-16-2012 03:55 PM
Kidde Smoke Alarm Battery Replacement e-Andy Electrical 0 12-29-2011 12:32 PM
Car Horn Alarm Clock carpenterty Electrical 13 01-04-2011 04:13 PM
Physco Alarm... McGaw General DIY Discussions 13 02-15-2008 02:45 PM
