Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 11-21-2011, 01:34 AM   #1
setting up gas stove
i attached the gas line to the stove, after putting the tape on the
threaded areas.
I turned the threaded nut to tighten. then checked for leaks
it is still bubbling when doing water and soap test.
I tightened again.. Still bubbles
What should I do now????
I have redone several times.
cmerz is offline   Reply With Quote
Old 11-21-2011, 01:44 AM   #2
I'm Your Huckleberry
The Home Depot.
Doc Holliday is offline   Reply With Quote
Old 11-21-2011, 08:58 AM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
call professional !!
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 11-21-2011, 10:07 AM   #4
Flex line?? if so, you don't put *gas rated tape* on flare fitting, just on pipe coming out of the range.
Jacques is offline   Reply With Quote
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
Do you have a Wood/Pellet Stove Insert with a Raised GRANITE Hearth? gmoom Remodeling 1 01-24-2011 05:54 PM
Burner always stops at LOW setting on L8124L pleasehelpmike HVAC 2 01-19-2011 09:22 AM
Wood burning stove trim not flush against chimney Fortitude Appliances 1 11-11-2010 10:28 PM
Wood Stove, and Furnace hot water system shendog HVAC 7 10-04-2010 10:30 PM
