It Serves Me Right - Now My Dryer Won't Work - Appliances - DIY Chatroom Home Improvement Forum
Old 04-28-2008, 09:41 PM   #1
Learning by Doing
Leah Frances's Avatar
It serves me right - now my dryer won't work
I switched my dead washer for my working front loader this weekend. I decided to switch the dryers too on the theory that if the old washer broke then the old dryer would probably too.
Hooked up my front loader - all's well.
Hooked up my dryer - got four loads dried then it died.
So either Karma is a b*tch, or something broke. OR, when I opened up the dryer to vacuum out the lint I broke something.
Dryer: Kenmore 110.63932101. Dryer will not run unless 'Push to Start' button is depressed. I used the Diagnostic test and the timer failed. So, it seems like I need a new timer. Is there a way I can confirm this? I know lots of people have had trouble with the 'evenheat' control board. And given my luck, I'm worried I might have to replace that too. How can I figure out what broke?
Sigh. I am definitely getting down about this.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 04-28-2008, 11:56 PM   #2
jeff1's Avatar
Hi,
Often a bad board, relay, temp thermistor, motor....the board being most common.
Yup!
Maybe bypassing a contact in the timer with the wire diagram-tech sheet?
Might help as well...
http://www.applianceaid.com/evenheat.html
jeff.
Appliance Repair Aid
JRAppliance
www.jrappliance.ca
jeff1 is offline   Reply With Quote
Old 04-29-2008, 01:38 PM   #3
Learning by Doing
Timer, PTS button, door, and thermal fuse tested: OK.
Put everything back together, buttoned it up. Pressed the PTS and Ill-be-darned, it runs. I considered myself warned that the control panel may need to be replaced. But, for now, I seem to have gotten lucky.
I assume that either I jarred a connection when I opened it, or the control panel has an intermittent problem. We'll see.
Old 04-29-2008, 02:42 PM   #4
jeff1's Avatar
True.
Maybe the motor relay got jiggled?!?
jeff.
JRAppliance
www.jrappliance.ca
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
HVAC contractor ripoff! sekntonone HVAC 8 04-05-2008 07:15 AM
Dryer vent. kcrossley2 Plumbing 10 02-20-2008 12:02 AM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 09:16 PM
