-   -   It serves me right - now my dryer won't work (http://www.diychatroom.com/f47/serves-me-right-now-my-dryer-wont-work-20434/)
Leah Frances 04-28-2008 09:41 PM
I switched my dead washer for my working front loader this weekend. I decided to switch the dryers too on the theory that if the old washer broke then the old dryer would probably too.
Hooked up my front loader - all's well.
Hooked up my dryer - got four loads dried then it died.
So either Karma is a b*tch, or something broke. OR, when I opened up the dryer to vacuum out the lint I broke something.:laughing:
Dryer: Kenmore 110.63932101. Dryer will not run unless 'Push to Start' button is depressed. I used the Diagnostic test and the timer failed. So, it seems like I need a new timer. Is there a way I can confirm this? I know lots of people have had trouble with the 'evenheat' control board. And given my luck, I'm worried I might have to replace that too. How can I figure out what broke?
Sigh. I am definitely getting down about this. :(
jeff1 04-28-2008 11:56 PM
Hi,
Often a bad board, relay, temp thermistor, motor....the board being most common.
Yup!
Maybe bypassing a contact in the timer with the wire diagram-tech sheet?
Might help as well...
http://www.applianceaid.com/evenheat.html
jeff.
Leah Frances 04-29-2008 01:38 PM
Timer, PTS button, door, and thermal fuse tested: OK.
Put everything back together, buttoned it up. Pressed the PTS and Ill-be-darned, it runs. I considered myself warned that the control panel may need to be replaced. But, for now, I seem to have gotten lucky.
I assume that either I jarred a connection when I opened it, or the control panel has an intermittent problem. We'll see.
jeff1 04-29-2008 02:42 PM
:biggrin:
True.
Maybe the motor relay got jiggled?!?
jeff.
