Securing Generator - Appliances - DIY Chatroom Home Improvement Forum
Old 05-21-2013, 04:29 AM   #1
securing generator
How do I keep generator from theft while it's in use on a deck?
generatorguy is offline   Reply With Quote
Old 05-21-2013, 05:42 AM   #2
Rewards Points: 1,296
Chain and a lock
danpik is offline   Reply With Quote
Old 05-21-2013, 06:18 AM   #3
DIY staff
Rewards Points: 7,174
Originally Posted by danpik View Post
Chain and a lock
Add a chain to a big dog--- Good luck, A friend in DC had two window air conditioners swiped----
Old 05-24-2013, 06:43 PM   #4
Rewards Points: 66
Ar 15. Back during Ike here in Houston they would role up with a lawnmower running and take the generator during the night
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 05-24-2013, 06:53 PM   #5
Rewards Points: 13,732
Move to a better area.
Old 05-24-2013, 11:53 PM   #6
" Euro " electrician
frenchelectrican's Avatar
Put a freaking large U bolts and drill out couple holes on the deck and lock it down and when some sucker try to steal it they will never take it out without makeing noise.
I have done that before it took them alot of effort and gave them a birdshot in the arse.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
oh'mike (05-25-2013)
Generator & Interlock Kit Float the Neutral? Arnold Ziffel Electrical 12 01-13-2013 05:28 PM
A discussion on the Proper grounding for portable generators Stubbie Electrical 41 07-05-2012 10:15 PM
Generator connection Question - Final Plan Apollo67 Electrical 24 01-30-2012 07:44 PM
B&S Generator with Connecticut Electric Xfer Switch Rick5150 Electrical 19 01-20-2011 10:14 PM
