Secondary Lint Trap Leak - Appliances - DIY Chatroom Home Improvement Forum
Old 05-26-2013, 12:14 PM   #1
I currently live in a condo with a W/D room on the second floor. There is a secondary lint trap, and the screen sits inside a compartment above the dryer. This compartment is not sealed and therefore leaks moist, lint-filled air into the condo.
Is there a solution to this? Are there secondary lint trap compartment doors that have a latching system to ensure it remains shut during operation?
Any and all help is appreciated.
-Nate
Littner88 is offline   Reply With Quote
Old 05-26-2013, 12:24 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,162
Secondary? Do you also have one inside the dryer?
In either case, it sort of sounds like you might have a blockage in the exhaust....especially if you have a lot of air coming out the seams.
Old 05-26-2013, 12:24 PM   #3
Rewards Points: 13,300
Got a picture?
Old 05-26-2013, 09:00 PM   #4
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
it should be removed, them things are worthless.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Leak every 5 months LValley Plumbing 4 11-05-2012 02:12 PM
Central Air Secondary Drain Leaking - 3 questions walters_12 HVAC 7 05-11-2011 04:20 PM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 01:47 PM
Freon Leak captainron19 HVAC 3 04-16-2010 05:30 PM
