Second Gas Dryer To Same Gas Line? - Appliances - DIY Chatroom Home Improvement Forum
Old 01-05-2010, 01:41 PM   #1
Second Gas Dryer to Same Gas Line?
I currently have a gas dryer and an electric dryer. The electric died and I want to replace it with another gas dryer.
Can I connect the second gas dryer to the same gas line as the first? Believe it's a 5/8" line. Figured I could put a T at the end and connect both, but not sure there's enough capacity for both.
Thanks!
Steve
sjroo is offline   Reply With Quote
Old 01-06-2010, 03:50 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 396
IMO this is a job for a licenced plumber and not a DYI job but that is just me, maybe. I would not endanger my family and my home by doing this myself.
Old 01-06-2010, 08:15 AM   #3
The work itself is very easy and straightforward. Just need to know if the pipe is large enough to deliver gas to both appliances.
Thanks.
Old 01-06-2010, 12:56 PM   #4
An old Tradesmen
Rewards Points: 7,414
You need to know the BTU input of both units. And the length of the gas line run.
Total length of the run. From the gas meter to these driers.
Old 01-24-2010, 06:13 PM   #5
The dryers would be 22K BTU each for a total of 44K.
The final run is about 15ft of 1/2". Before that is something bigger than an inch for about 20ft.
Can I run both dryers off the one 1/2" line?
Thanks for the help!
Old 01-24-2010, 06:17 PM   #6
An old Tradesmen
If the lines feeding the 1/2" is large enough for the "total" load of all appliances. Yes.
Old 01-24-2010, 06:40 PM   #7
Thanks! So I've got pipe coming into the house that's an 1 3/8" OD.
Got:
Water Heater 34K BTU's
Furnace 100K BTU's
Dryer 22K BTU's
Total 156K BTU's
Can I add another 22K BTU dryer?
You've been a great help!
Old 01-24-2010, 07:00 PM   #8
An old Tradesmen
You need the size of pipe and length of run to each appliance yet.
But, 1-1/4" steel pipe carry handle 210,000 BTUs at a length 200'
Now if that is the size pipe that runs up to the 1/2" pipe that goes to the dryers. Then yes, it will handle it.
1-3/ OD steel pipe is 1-1/4" ID pipe.
Old 01-25-2010, 08:43 AM   #9
Rewards Points: 530
If you have never done this type work before I agree. Your day could go sour in a flash.
gas dryer connection question rvegab00 Plumbing 7 12-07-2009 10:53 AM
Replacing damaged BX line in kitchen wall fishnyc22 Electrical 5 02-17-2009 12:40 PM
Electric Dryer wiring/plug question SpaceCrawler Electrical 6 08-26-2008 04:33 PM
Gas line for dryer helpless handyman Plumbing 18 01-28-2008 05:11 AM
Problem with ELECTRIC DRYER plugs SpaceCrawler Appliances 6 06-03-2007 10:21 AM
