Sears Craftsman Garage Door Opener Bearing Assembly? - Appliances - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-12-2014, 09:12 PM   #16
Remodeler
Rewards Points: 298
Yep, no pics needed, I got one that looks identical that I installed in 1984. They only used the dip switches until 91 or 92 but the silver cover likely means it's closer to mid 80s.
You can buy the bushings and http://www.amazon.com/LiftMaster-Sprocket-41C4220A-Chamberlain-Craftsman/dp/B006L8CZKI/ref=sr_1_4?ie=UTF8&qid=1394669626&sr=8-4&keywords=chamberlain+gear+kit, if the motor or motor shaft isn't hurt from the shaft traveling back and forth. The end of the motor shaft may be worn beyond being usable, hard to tell without close inspection what exactly has worn out.
You can get just the gears and bushings a little cheaper without the main shaft, but I have also seen the shaft cut itself right off under the sprocket when that bushing goes. Probably mostly due to the chain being overtightened.
About the only problem with any of these is eventually the big plastic gear will wear out. It will usually last 15+ years, but if you have a door that works poorly, catches, sticks or the opener has to do too much the gear can be destroyed very quickly. I use the Chamberlain brand, have put up a couple from Sears and a few of the "Do It Best" brand from the local home center. I have never really found much of a difference in the brands, other than the remotes and wall controls may look a little different.
iamrfixit is online now   Reply With Quote
The Following User Says Thank You to iamrfixit For This Useful Post:
r0ckstarr (03-13-2014)
Old 03-12-2014, 10:35 PM   #17
Rewards Points: 6,652
I actually use the Bike Lube grease that comes in the Green tube, that you get from the bike shops, on the gears. Stays on even in cold weather. Actually quiets the gears then just using standard grease.
For the chain, I just use Bike chain lube. When I went over to my niece's house last Summer. Her father in law had over oiled the chains on her openers so much, that it was dripping off of the chain as you stood there looking.
The Following User Says Thank You to gregzoll For This Useful Post:
Old 03-13-2014, 08:39 AM   #18
r0ckstarr's Avatar
Rewards Points: 1,978
Thanks again for the help everyone!
I ordered this Chamberlain Model# PD212D.
http://www.sears.com/shc/s/p_10153_12605_00990358000P
I should have it in a week. Until then, I am going to explore rebuilding my old Crafstman. Tomorrow, i'll pull the old one down and have a closer look at everything to see how bad it is.
r0ckstarr is online now   Reply With Quote
Old 03-16-2014, 11:36 AM   #19
r0ckstarr's Avatar
I pulled the Crafstman down and opened it up again to get a better look at the end of the shaft.
Here's the pile of dust/metal shavings that was in the cover.
The snap ring and washers that were the only loose things on the shaft between the rpm sensor and the plastic bushing that holds the shaft in place. I can slide the shaft a full 1/2" - 3/4" forward or backwards.
Here's a close-up of the shaft where the snap ring and washers were.
How worn is the shaft? Too worn for new parts?
Oh, and here's why the light socket was held in with tape.
Old 03-16-2014, 02:36 PM   #20
Looks like they had a 100 watt bulb in the light socket. As for the shaft. Yep, looks a little worn for wear.
Old 03-16-2014, 02:54 PM   #21
r0ckstarr, I am still willing to take the remotes off of your hand, for the old unit. Just let me know what the shipping cost is, and I will work it out with you.
Old 03-16-2014, 05:47 PM   #22
Remodeler
Rewards Points: 298
Looks done for, never going to work right with that much wear. The cost of a replacement motor is probably going to be more than it's worth. You might find a used one on ebay but really not sure its worth the effort.
Old 03-27-2014, 09:56 AM   #23
r0ckstarr's Avatar
I got the new one in and put it up with all of the new parts. Perfect fit in the same place as the old. I never realized just how loud my old one was until I ran the new one.
I've decided against rebuilding the old one. You guys were right. The cost of the new motor is almost the cost of a new opener all together. I searched everywhere, and couldn't find a new motor at a reasonable price, and eventually gave up looking.
The Following User Says Thank You to r0ckstarr For This Useful Post:
jmon (03-27-2014)
Tags
craftsman , garage door opener , screech , sears
Garage door water barrier eharri3 Building & Construction 3 01-14-2014 09:01 AM
unconditioned garage reillyoevans HVAC 3 08-20-2011 07:29 PM
Sears belt drive 1/2 hp garage door opener pcampbell Appliances 4 03-27-2011 11:44 AM
Craftsman garage opener freeonthree Electrical 2 11-01-2008 04:32 PM
Garage Conversion: Loading Bearing Foundation wrldruler Building & Construction 3 08-26-2008 10:11 PM
