Saltless Water Softeners - Appliances - DIY Chatroom Home Improvement Forum
Old 02-04-2014, 05:32 PM   #1
Painting Contractor
Rewards Points: 79
Saltless water softeners
Does anyone know if the saltless water softeners are any good. If so, are there particular brands that are better than others?
VAProPainter is offline   Reply With Quote
Old 02-04-2014, 08:43 PM   #2
Rewards Points: 140
you can put potassium chloride in a regular water softener. but it is much more expensive.
Fix'n it is offline   Reply With Quote
Old 02-05-2014, 10:30 PM   #3
chitownken's Avatar
Rewards Points: 510
Potassium can also cause problems for people with kidney issues or certain heart conditions.
I think the OP was referring to the "electronic" water softeners that don't use ion exchange technology. Don't know anybody that has ever tried one.
chitownken is offline   Reply With Quote
Old 02-07-2014, 04:08 PM   #4
Rewards Points: 106
Would that be a magnetic softener ?
Cedrus is offline   Reply With Quote
Old 02-07-2014, 05:50 PM   #5
Painting Contractor
Rewards Points: 79
I think so, the Nuvo softener ad pops up on this site often.
Old 02-08-2014, 07:35 AM   #6
Rewards Points: 140
i wonder if that is the kind that a guy my wife invited over was trying to sell us. for $6000, and that is with the discount. sheeesh
Old 02-10-2014, 08:45 PM   #7
Rewards Points: 808
I don't think you can soften water without salt.
IslandGuy is offline   Reply With Quote
The Following User Says Thank You to IslandGuy For This Useful Post:
Live_Oak (02-11-2014)
Old 02-10-2014, 10:48 PM   #8
chitownken's Avatar
Rewards Points: 510
Well, you can't remove the ions without salt. But the saltless water softeners claim that they reduce/remove the bad effects of the ions with out removing the ions. They only claim to reduce/remove limescale deposits. They apparently can eliminate limescale deposits on your showerhead and faucets and in you appliances, but the effect of the magnetic "excitation" of the limescale wears off after a few hours so it probably won't help the water heater much. It also won't prevent the formation of insoluble compounds, which is why detergents don't work as well in hard water.
If you want/need to avoid sodium, they might be a good alternative. If you don't care about your sodium intake, then a traditional softener does a much better job.
Old 02-11-2014, 10:24 AM   #9
Rewards Points: 106
I don't know that much about a softener. We have had one for four years. I was apprehensive about sodium in our drinking water. We have had about six lab tests to check our water after going thru the softener. All tests showed......little or none. I'll see if I can dig up the actual numbers if anyone is interested.
The fresh water rinse of the plastic media takes care of any residual salt.
Old 02-11-2014, 12:25 PM   #10
I looked into these "water softeners" that you're describing several years ago; my research led me to believe that this is pretty much a scam, but do your own research and make your own conclusion.. I don't love the way a normal water softener functions, but I understand the chemistry behind it now and why salt is used.
RobbM is offline   Reply With Quote
How to seal water line on outside to prevent leak into basement goshenplumber General DIY Discussions 14 10-27-2013 02:56 AM
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 01:59 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
