Safe Way To Keep Bath Water Warm? - Appliances - DIY Chatroom Home Improvement Forum
Old 10-04-2010, 08:50 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
Safe way to keep bath water warm?
I have a condition that pops up every now and then and one of the remedies is to take a salt water bath. I was thinking of doing this regularly just to prevent it from coming up in the first place, that and it's overall good for the body once and a while.
The issue I face is the water does not stay hot long enough. Rather then keep running more hot water, I was thinking, it would be more efficient to somehow keep the water warm with some kind of device.
Is there such device I can buy made for this? I'm thinking, some kind of pump with two hoses or something, and just circulate/heat the water, and plugs into a GFCI outlet. Probably not hard to make, but rather buy if one exists.
Old 10-04-2010, 09:21 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
ya, a hot tub.
Old 10-04-2010, 09:45 PM   #3
Wire Chewer
Rewards Points: 46
Without replacing the whole bath. LOL
Old 10-04-2010, 10:11 PM   #4
Rewards Points: 192
Is there a way for you to access the outside walls of the tub? If you spray foam insulation all the way around it and underneath, it'll stay hot a lot longer.
gma2rjc is online now   Reply With Quote
Old 10-04-2010, 10:22 PM   #5
nap
You talking to me?
nap's Avatar
this seems to work for some
If you can set the thermostat low enough, maybe something like this and a low gpm pump.
http://www.homedepot.com/webapp/wcs/...3&marketID=300
The Following User Says Thank You to nap For This Useful Post:
Bondo (01-26-2013)
Old 10-04-2010, 10:37 PM   #6
HVAC / Plumbing
good 1
kenmac is offline   Reply With Quote
The Following User Says Thank You to kenmac For This Useful Post:
joecaption (01-26-2013)
Old 10-04-2010, 10:43 PM   #7
nap
You talking to me?
nap's Avatar
just to be clear, the pic was for fun. It is not associated with the statement and link below it.
Old 10-04-2010, 10:44 PM   #8
When I redo our bath I'm thinking of wrapping the new tub in pex & connect it to a sm water heater
Or existing WH
I think they make portable spa units that hang on the side of a tub
Old 10-04-2010, 10:44 PM   #9
nap
You talking to me?
nap's Avatar
Originally Posted by kenmac View Post
good 1
If you think that is funny, you ought to see my spider mitigation method I suggested for red in another of his threads.
Old 10-04-2010, 10:49 PM   #10
Wire Chewer
Rewards Points: 46
I was actually thinking something like that may work. I'm surprised there is no actual device made for this though, but so far I'm not finding anything.
Really one thing that I should have done before the contractor installed the bath was to put some pex tubing coiled up under it, for future radiant heat. That could be cool to have.
Old 10-04-2010, 11:05 PM   #11
nap
You talking to me?
nap's Avatar
there is this type of heater unit but you would still need a pump.
http://www.foodclassics.com/store/wh...650328138.html
then there is this which apears to be both pump and heater:
http://www.aliexpress.com/store/2010...pa-heater.html
Old 01-26-2013, 02:41 PM   #12
Legionnella?
Anyone worried about Legionnaire's Disease and other diseases in such a situation?
Wikipedia says warm water is the ideal breeding ground for Legionella.
dcoyle is offline   Reply With Quote
Old 01-26-2013, 02:55 PM   #13
Rewards Points: 12,886
Happen to have forced air heat? Just add another line under it.
Old 01-26-2013, 03:22 PM   #14
Master General ReEngineer
Bondo's Avatar
Rewards Points: 360
Ayuh,... There's always the redneck hot tub,...
Bondo is online now   Reply With Quote
Old 01-26-2013, 03:24 PM   #15
Bondo's Avatar
Rewards Points: 360
Ayuh,... Diggin' Deep into the archives are We,..??
I just saw the date on this thread,... (no wonder the links don't work)
What's been proposed is a closed loop system,...
So,... No, nobody's gonna drink the water...
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 04:01 PM
help Chuckman Off Topic 8 06-15-2006 11:06 PM
NO bath water running!!! rath Plumbing 1 09-09-2005 01:13 PM
