Ruud Furnace Not Heating/staying On - Appliances - DIY Chatroom Home Improvement Forum
Old 01-30-2011, 10:19 AM   #1
Ruud furnace not heating/staying on
Problems with Ruud furnace not staying on. Pilot light comes on, but when blower comes on the pilot light goes out. Also, when the high efficiency thermostat heats to desired temp and goes off, it does not come back on.
jwhiteh is offline   Reply With Quote
Old 01-30-2011, 10:34 AM   #2
Experienced
Jackofall1's Avatar
You might want to find the model #'s of the equipment you are referring to, this makes things much easier on this end for finding the pertinent information to assist you.
The Following User Says Thank You to Jackofall1 For This Useful Post:
jwhiteh (01-30-2011)
Old 01-30-2011, 10:44 AM   #3
Ruud furnance
The Model number to our furnace is UGFD06EMEKE. We think it might be in the wiring between the thermostat and furnace.
Old 01-30-2011, 10:53 AM   #4
Experienced
Jackofall1's Avatar
This statement is confusing, as the thermostat doesn't heat, is what you are trying to say, the furnace cycles until the thermostat is satisfied, but it doesn't cycle again after its off, even when the temperature falls below the set point of the tstat.
Sounds like you have (2) problems, you mention that the furnace doesn't run in the first line, and then in the second ine you say it only runs once and shuts down and won't restart, is this correct?
Old 01-30-2011, 11:06 AM   #5
Experienced
Jackofall1's Avatar
Have you looked at the control board to see what codes are flashing?
Old 01-30-2011, 11:23 AM   #6
YES it flashes 6 7
Old 01-30-2011, 11:42 AM   #7
Jackofall1 you still there?
Old 01-30-2011, 11:50 AM   #8
Experienced
Jackofall1's Avatar
Yes, I was doing some research, as I am not real familiar with your furnace.
Was hoping "beenthere" or "Yuri" would chirp in here they really know there stuff.
Couple of questions
What thermostat do you have?
Have you tried to run the unit as a (2) stage?
Have you tried to cycle power to the unit to clear the faults?
Mark
Old 01-30-2011, 02:50 PM   #9
Experienced
Jackofall1's Avatar
Have you figured out what the problem is yet?
Old 01-30-2011, 03:46 PM   #10
Furnace
Repairman who put furnace in came over and replaced programmable thermostat with the old-fashioned kind.....works a little better, but we think it's in the wiring between thermostat and furnace. He doesn't think that's it, but we are making him replace wiring anyway to rule it out.
Old 01-30-2011, 03:51 PM   #11
Experienced
Jackofall1's Avatar
Cool man, or should I say warm man, nice to see you are at least more comfortable and thanks for posting back. We like to see the ending as well as the beginning, even if I wasn't very helpful.
Old 01-30-2011, 03:52 PM   #12
Furnace
Will post the final outcome! We've been messing with this all week -- the furnace is only about 2 years old and it's ridiculous that the guy who put it in can't seem to figure out what's wrong! Thanks for your input!
Old 01-30-2011, 09:33 PM   #13
Rewards Points: 530
Is this a central unit? Split system? In the attic?
Old 01-30-2011, 10:50 PM   #14
Experienced
Jackofall1's Avatar
I believe its a 60K Btu/hr modulating updraft furnace.
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Ruud furnace makes loud boom starting up ruud HVAC 5 01-16-2011 10:16 PM
Ruud furnace problem Paul T. HVAC 8 12-07-2008 06:25 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
