Roper Washer Drum Moves - Appliances - DIY Chatroom Home Improvement Forum
Old 02-10-2013, 04:50 AM   #1
Roper washer drum moves
Whenever my older Roper washer go on spin cycle the drum moves to the right and makes a loud banging sound like its off balance. I have checked the springs and they are all intact. Any suggestions would be appreciated.
Brokemom is offline   Reply With Quote
Old 02-10-2013, 09:15 AM   #2
Rewards Points: 14,312
Go back and add the model #.
Old 02-10-2013, 01:49 PM   #3
Rewards Points: 83
Make sure it's level. Make sure the support system is ok, springs can lose tension and still 'look' ok. Most importantly, make sure your clothes are evenly spread out in the drum. That's pretty much the only things that will cause the washing machine to bang.
Protocol. is offline   Reply With Quote
Old 02-10-2013, 03:32 PM   #4
Model # is RAL6245BW1
Old 02-10-2013, 08:41 PM   #5
http://www.repairclinic.com/RepairHe...roubleshooting
Brokemom (02-11-2013)
Maytag washer drum very tight. thunderhead Appliances 3 05-06-2012 03:41 PM
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 11:00 AM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
LG Washer not putting water in the drum RuralPrincess47 Appliances 4 07-28-2010 12:50 PM
Sears front load washer drum Joe F Appliances 0 06-17-2010 05:55 AM
