Roper 2041B40 Oven Door Hinge Issues - Appliances - DIY Chatroom Home Improvement Forum
Old 04-03-2014, 04:54 AM   #1
Rewards Points: 91
Roper 2041B40 oven door hinge issues
Need a manual for Roper built-in oven model 2041B40.
When I open the door the bottom left side pulls out from the oven while the right side, as is normal, simple pivots on the hinge. When closing it the left side does not want to pivot back into the closed position but instead makes some binding and clunking noises. While inspecting it, after living with this for 5 years, I noticed that there is a locking device on the hinge that is not locked in place...DUH! I pushed the lever down and now the door closes better but still does not seal good against the oven body.
I'll take any advice but mainly I need a manual. It looks like a little understanding of its parts will make repair a simple project.
sofasurfer is offline   Reply With Quote
Old 04-03-2014, 09:35 AM   #2
Rewards Points: 13,300
Just Google the model # and add the word manual to the end of it. Lots of them came up.
There also on the Roper website and all the parts are listed on repairclinic.com.
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 03:19 PM
Oven Blew Up at Connector with Element cynthiap Appliances 6 10-31-2015 10:48 AM
30amp oven on 40amp breaker Improvised Electrical 28 05-27-2011 12:48 AM
oven door seal replacement, self-cleaning function malfunction YerDugliness Appliances 10 02-28-2011 10:22 PM
Counter top trim to fit with slide in oven bhagey Appliances 1 07-17-2009 09:32 AM
