Reset Error 41 On Oven - Appliances - DIY Chatroom Home Improvement Forum
Old 06-02-2012, 07:49 PM   #1
Reset error 41 on oven
Was using the self cleaning the oven. Error code41 appeared, I can;t reset it. Can't unlock the key pad. Bosch Oven & range
L1963E is offline   Reply With Quote
Old 06-02-2012, 07:52 PM   #2
Rewards Points: 484
Originally Posted by L1963E View Post
Was using the self cleaning the oven. Error code41 appeared, I can;t reset it. Can't unlock the key pad. Bosch Oven & rangf
I guess what i would do is shut off the breaker for a min or so and see if that does reset??
del schisler is online now   Reply With Quote
Old 06-02-2012, 08:37 PM   #3
Rewards Points: 83
unplug or switch the breaker for a min or two then reset. Looks like it has to do with the oven door lock not operating properly. Check wiring and any possible pinch points.
Protocol. is offline   Reply With Quote
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 02:19 PM
Kenmore Oven Element Arcing Valerie1960 Appliances 2 01-30-2012 08:03 AM
Roper Electric Oven Range Problem mcnutty Appliances 6 07-05-2011 05:32 PM
Dispute: Oven malfunction after h/w guys used the circuit rational Appliances 18 05-17-2011 10:37 PM
Gas oven problems gregsmy Appliances 1 12-03-2009 05:55 AM
