Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 11-01-2010, 11:27 AM   #1
replacing oven
can you replace a built in oven/cooktop with a free-standing range?
creed is offline   Reply With Quote
Old 11-01-2010, 11:49 PM   #2
firehawkmph's Avatar
replacing oven
Normally you can, as long as you can get the same width unit as the old one. You may have to cut out a little of the countertop in the rear and backsplash if any. Also might have to remove any toekick in the width where the stove goes. Shouldn't be too hard.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 11-05-2010, 10:11 AM   #3
replacing oven
yes it is a standard practice for many kitchen remods have a look at this link might help you Replacing countertop stove and built in oven
Bobby_B is offline   Reply With Quote
Old 11-05-2010, 07:31 PM   #4
replacing oven
I asked the same question to an electrician at my place (replace existing cooktop with regular range) and he stated that I would need to pull bigger wire (possibly with a larger breaker? Can't remember) since I have two separate circuits to the appliances.
Not sure what your situation is, but maybe keep the possibility in mind.
burnt03 is offline   Reply With Quote
Old 11-05-2010, 10:06 PM   #5
I ask the impossible!
replacing oven
Was it a gas to electric conversion involved? Certainly if so there will need to be a new 240 circuit run for the new electric range.
IMO depending on configuration, the cabinet work may be the bigger part of the project.
WillK is offline   Reply With Quote
SCARY oven fire! Why did it burn? Beth777 Appliances 63 01-20-2013 07:55 PM
Cooktop and Stand Alone Oven Wiring Replacing Existing Single Range/Stove Combination ffauth Electrical 3 08-23-2010 10:03 PM
Replacing an oven install liquidvw Electrical 7 11-09-2009 03:34 PM
Replacing Electric Built In Oven handygirl37 Appliances 2 09-09-2008 09:38 PM
Replacing countertop stove and built in oven becky3501 Carpentry 9 06-27-2008 09:41 PM
