Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 10-09-2011, 11:24 AM   #1
Replacing an electric range with a gas range.
I have NG in the house, running thru the crawl space. The gas runs thru a regulator after the meter and just inside the house before it splits off to the hot water heater and to the gas fire log. There is another regulator on the line to the gas fire log. The new range has a regulator built ion. Do I need another in line regulator to the range?
hazardmf is offline   Reply With Quote
Old 10-09-2011, 02:59 PM   #2
Msradell's Avatar
I wouldn't think so but to be safe you need to verify what the line pressure is on the existing line (the regulator feeding it should be marked). Then compare this pressure to the manufacturer's rating for the stove to be sure it's within the acceptable range.
Msradell is offline   Reply With Quote
Old 10-09-2011, 04:43 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
no you will need no other regulator
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
replacing a electric stove with a gas stove love2doitmyself Appliances 3 04-06-2011 10:37 PM
Electric Range Breaker Size mkeehn64 Electrical 0 03-21-2011 09:46 AM
Gas or electric range Josie Appliances 5 05-02-2007 04:23 PM
Electric Range Wiring manhattan42 Electrical 11 07-05-2006 06:03 PM
Replacing Stove Top with Range the.vicster Electrical 3 02-23-2006 06:12 PM
