Replacing Drop-in With Slide-in Range Will It Fit? - Appliances - DIY Chatroom Home Improvement Forum
Old 01-07-2008, 01:50 PM   #1
Replacing Drop-in with Slide-in Range will it fit?
I ordered a Frigidaire 30 slide-in #FES3555ES that will arrive in a week, to replace a Westinghouse drop-in # KD220GDD2 (could be KD220G002) I pulled the drop-in out some to see what I would have to do to the bottom and found out my cabinet opening as well as the cut out is only 29 3/8 not 30 . Will the new slide-in fit?
Tim
TLT01 is offline   Reply With Quote
Old 01-07-2008, 02:35 PM   #2
To make sure you should call your sales person.
The slide-in does not have side panels so it may fit.
girltech is offline   Reply With Quote
Old 01-07-2008, 02:45 PM   #3
I checked with them and they can only wait to see when it comes in but it is built for a standard 30" open but so is the one I am taken out.
Old 01-07-2008, 09:33 PM   #4
Thank to all ! Yes it will fit in as little as 29" opening with option kit. I was led to Frigidaire online Installation Instructions.
Old 01-09-2008, 01:11 AM   #5
mtm
Rewards Points: 18
TL yeah you should have no problem with it fitting in your previous space. You may have to do a little electric work though. Most of the drop ins are hard wired. Most slide ins have plugs.
mtm is offline   Reply With Quote
gas range swap kenny11876 Appliances 2 02-20-2008 09:31 PM
Replacing Drop-in with Slide-in Range will it fit? TLT01 Carpentry 3 01-07-2008 09:23 PM
Drop In Range Hook-Up mickey45 Electrical 1 04-08-2007 10:29 PM
Electric Range Wiring manhattan42 Electrical 11 07-05-2006 06:03 PM
Replacing Stove Top with Range the.vicster Electrical 3 02-23-2006 06:12 PM
