-   -   Replacing Drop-in with Slide-in Range will it fit? (http://www.diychatroom.com/f47/replacing-drop-slide-range-will-fit-15298/)
TLT01 01-07-2008 12:50 PM
I ordered a Frigidaire 30 slide-in #FES3555ES that will arrive in a week, to replace a Westinghouse drop-in # KD220GDD2 (could be KD220G002) I pulled the drop-in out some to see what I would have to do to the bottom and found out my cabinet opening as well as the cut out is only 29 3/8 not 30 . Will the new slide-in fit?
Tim
girltech 01-07-2008 01:35 PM
To make sure you should call your sales person.
The slide-in does not have side panels so it may fit.
TLT01 01-07-2008 01:45 PM
I checked with them and they can only wait to see when it comes in:eek: but it is built for a standard 30" open but so is the one I am taken out.
TLT01 01-07-2008 08:33 PM
Thank to all ! Yes it will fit in as little as 29" opening with option kit. I was led to Frigidaire online Installation Instructions.
mtm 01-09-2008 12:11 AM
TL yeah you should have no problem with it fitting in your previous space. You may have to do a little electric work though. Most of the drop ins are hard wired. Most slide ins have plugs.
