Replacing Door Seal On Front Load Washer - Appliances - DIY Chatroom Home Improvement Forum
Old 03-06-2012, 09:51 AM   #1
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 688
Replacing door seal on front load washer
I have an LG WM2032HW Washer. There was previously a drip from the front door. Now it is more like a stream, so it's time to address this problem.
Looks like a new door seal is about $55. I don't have a repair manual, but from reading online it looks like you have to disassemble darn-near the whole machine to get to the spring clips holding the seal in place.
Has anyone replaced a front door seal before? Am I better off calling in a repair man that knows what he's doing on this one?
hyunelan2 is offline   Reply With Quote
Old 03-06-2012, 09:57 AM   #2
Rewards Points: 13,444
Are you 100% sure it's the door seal. Most front loading machines have the boot start leaking between the front frame and the drum long before the door seal would leak.
Old 03-06-2012, 10:21 AM   #3
hyunelan2's Avatar
Rewards Points: 688
The boot/door seal is all one piece of rubber.
Old 03-06-2012, 11:18 AM   #4
Have you looked at this vidio?
http://www.repairclinic.com/Washing-...liance-Diagram
Old 03-06-2012, 01:55 PM   #5
hyunelan2's Avatar
Rewards Points: 688
That video made me think to search Youtube... honestly that should have been my first step.
It doesn't look all that hard, I should probably be able to do it in much less time than I had initially planned.
The only difference is, my controls are on top, not in the face of the washer. So that might make it a little different. Going to keep searching to see if I can see how that might come apart differently. Thanks for posting that link.
Old 03-06-2012, 03:09 PM   #6
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
its not really that hard, you should be able to knock it out in about 45 minutes. It requires a lot of disassembly but not a bad job.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 03-06-2012, 04:15 PM   #7
bbo
I don't know about the LG, but someone closed a towel in the door in their haste to start a load with my maytag once. Even though it was out of warranty, Maytag graciously offered to send me the door seal if I replaced it myself. It took me about 45 minutes to do mine. If I actually knew what I was doing at the time, I probably could have done it in 15. it was just like trying to fit a too small lid on a round tupperware container.
when I finally got it, I had a good laugh.
bbo is offline   Reply With Quote
LG Front Loading washer on second floor Mr Chips Appliances 11 10-20-2012 08:23 PM
Top load GE Washer kesmiller Appliances 4 10-15-2011 07:31 PM
Front Load Washer handy man88 Appliances 3 07-01-2008 10:16 AM
Recommendations on Front Loaders Washer/ Dryer helpless handyman Appliances 6 02-15-2008 10:59 AM
Replacing Front Door Lock hansi General DIY Discussions 2 06-21-2007 09:25 PM
