Replacing A 30" Electric Drop-in Range - Appliances - DIY Chatroom Home Improvement Forum
Old 12-07-2010, 01:54 PM   #1
Replacing a 30" Electric Drop-in Range
We have a 25 year old 30" electric drop-in range that needs replacing. The cut-out opening in the cabinet where the range is installed measures 29". All of the installation guides for new 30" drop-in ranges appear to require a cut-out opening of 30". Unfortunately, the counter tops in our kitchen are solid granite, so enlarging the cut-out is no simple matter.
Has anyone else encoutered this problem? Are there any 30" electric drop-in models on the market that only require a 29" cut-out? Outside of that, are there any other reasonable options I may want to consider?
Steve
SLC3271 is offline   Reply With Quote
Old 12-08-2010, 06:02 AM   #2
if you have a full service dealer[not chain] in your area they may be able to help..it happens a lot with built in appl..if i were you i'd have it pro' cut to 30" that way you could put whatever you want in there and when you replace it next time-no big deal.
Jacques is offline   Reply With Quote
The Following User Says Thank You to Jacques For This Useful Post:
SLC3271 (12-08-2010)
Old 12-08-2010, 07:22 PM   #3
Replacing a 30" Electric drop-in Range
Thanks so much for the advice Jacques. That is my feeling as well. I was just not sure how feasible it would be to cut-out a portion of the granite countertop without damaging the granite or its appearance.
Thanks again.
Steve
Old 12-08-2010, 10:46 PM   #4
firehawkmph's Avatar
Rewards Points: 1,884
Steve,
A good granite fabrication shop should be able to do that without too much trouble. Most of the jobs I have had done, the granite people would normally cut out the stove hole one the jobsite with the granite in position. They would use a 4" angle grinder with a diamond blade while a second guy holds a shop vac hose along side the grinder to minimize the dust.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
Thurman (12-09-2010)
Old 12-09-2010, 02:35 PM   #5
Thanks Mike. I will try contacting the people that cut and installed my granite countertops. Sounds like they should not how to do this.
Thanks again.
Old 06-10-2014, 09:22 PM   #6
I have the same problem replacing a 12 yr old Frigidaire Gallery slide in which took a 29" cut out. Have found it impossible to get a granite cutter to enlarge the cut out to 30". Somewhere I read that some oven manufacturers have Optional thinner sides available to solve this problem. Anybody know which manufacturers can do this? I am in Canada so need something CSA approved.
Robertsdaughter is offline   Reply With Quote
Pressure drop after replacing faucet seat plumbing_noob Plumbing 5 10-25-2010 09:14 AM
Point of use vs Whole Home Tankless Electric joergeske Plumbing 1 09-30-2010 03:52 PM
Drop Ceiling Prices? bengbrewer Remodeling 8 03-18-2009 02:00 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
Drop In Range Hook-Up mickey45 Electrical 1 04-08-2007 09:29 PM
