Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 05-11-2012, 03:46 PM   #1
replaced thermocouple on rheem water heater now burner turn off
what is making the burner ti turn off after it lights up for a few minutes
josepp7126 is offline   Reply With Quote
Old 05-11-2012, 04:10 PM   #2
MarginallyQualified
With a new (and properly installed) thermocouple the pilot light should stay on.
At this point you turn the controls from light (or pilot) to on and turn up the thermostat.
If the pilot light stays on, the valve is in the correct position and the main burner won't ignite...
then the issue is likely the operating valve itself. It happens.
Old 05-11-2012, 04:37 PM   #3
intake air, rollout sensor, chimney
danpik is offline   Reply With Quote
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
Water Heater Constantly Failing/Replaced DroidGuard12 HVAC 6 04-11-2012 04:41 PM
Rheem On Demand Water Heater b030smv Plumbing 1 01-05-2011 03:30 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Leaking Rheem 60 gal Electric Hot Water Heater aklkuno1 Plumbing 3 10-22-2008 11:13 PM
