Replaced Main Terminal Block - Appliances - DIY Chatroom Home Improvement Forum
Old 05-29-2010, 09:46 PM   #1
replaced main terminal block
i replaced the main terminal block because sparks came out the back of the dryer and burned up the terminal block. now the dryer seems to have no power coming to it. what did i hook up wrong? would that have fixed the problem? the dryer was still running while it was sparking. i unplugged it to stop it. the model number is fer311fs0
stowers is offline   Reply With Quote
Old 05-30-2010, 08:42 AM   #2
Rewards Points: 530
3 wire or 4 wire block?
Check the voltage at the block?
Check the wall rec?
Change the cord too?
What caused the sparking???
Bad main breaker? jm8891 Electrical 13 11-09-2013 10:32 AM
Block Foundation w/Hundred Seep Holes? Jodust11 Building & Construction 9 04-13-2010 11:41 AM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-06-2009 12:02 AM
Meter base and sub-panel wiring uokman Electrical 15 12-19-2008 02:41 PM
Main Service Disconnects rwlawrence Electrical 5 11-04-2008 11:46 AM
