Originally Posted by jogr
My 12 year old central vacuum hose has a lot of hairline surface cracks (that don't leak air) and has finally cracked through just before it enters the nozzle. The hose is dual electric (high and low voltage) for the powerhead.
I opened up the nozzle end and it looks like it might be possible to shorten the hose about 6 inches to eliminate the crack. But the high and low voltage wires are wound around and formed into the hose itself so I will need to carefully strip back the hose from the wiring.
Anyone on here ever do this and do you have any tips? Is there anything I can put on the hairline cracks to keep them from getting worse? A liquid plastic like you can coat tool handles with comes to mind. A replacement hose is going to be over $200.
Doesn't the hose need to flex? I wouldn't bother with this.
But if the manu. wants too many bucks because he knows you are locked into his product, get any kind of corrugated hose and run the wires.
How high is the higher voltage? It may not be 120v; they could use lower voltage and a high current (how long are the wires and what diameter) motor to get the same hp.
