Repair Power Cord On Dishwasher - Appliances - DIY Chatroom Home Improvement Forum
Old 04-07-2007, 06:51 PM   #1
Tile and Paint contractor
repair power cord on dishwasher
We recently adopted a 3 month old dishwasher
but luck has it the power cord is chewed off by a dog.
I rather keep it rather than bringing it to Habitat for Humanity.
I'm a tile guy and never touch electrical.
But it can be fixed can't it?
Matt | tile contractor
Charlotte, NC
MattCoops is offline   Reply With Quote
Old 04-07-2007, 07:29 PM   #2
Rewards Points: 1,088
Sure, check out the make's webpage for parts, or call a local distributo/repair company to see if they have it.
handy man88 is offline   Reply With Quote
Old 04-12-2007, 11:40 PM   #3
Yah, it can..If the space were your going to install the dishwasher has wire comin out of the wall, then just disconect the power cord from the dishwasher and use the wire comin out of the wall to go right into the D/W, If theres not, then just go to one of the Home centers and buy a Pig tail rated for a D/W, Wire it in and your good to go!
thom943 is offline   Reply With Quote
Old 04-13-2007, 02:17 PM   #4
Long-Time DIYer
Mike Swearingen's Avatar
DWs are supposed to have dedicated circuits. If you have a covered junction box behind or beside your DW cabinet base opening, you can straight-wire the DW to it (wire nuts). If you have a 3-prong receptacle, you can replace the wire from the DW with one that has a 3-prong plug on it (or just add a plug to the end, if the wire is still long enough). It should be wire-nutted inside a small box on the DW.
The wiring is simple. Black to black (hot), white to white (neutral) and bare or green to bare or green (ground). A plug and receptacle should have color-coded screws...brass for the hot (black) wire, silver screw for the neutral (white) and green for the ground. The wide blade of the plug is the neutral, and the round is the ground.
Make certain that the correct circuit breaker is OFF in the panel, of course, before dealing with anything installed, and test with a volt meter before touching.
DW wiring is basic and simple, but if you're uncomfortable at all with anything electrical, hire a pro.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 04-19-2007, 07:35 PM   #5
Dishwasher plug..
seems straight forward, except I bought the pigtail with plug (grey) and it has a labeled (center) green with yellow striped ground wire, but each wire on either side, is not color coded black or white, (breaker IS off) How do I know which of the wires each side of the ground wire goes to black and the which one goes to white?
Jeanbarb is offline   Reply With Quote
Old 04-19-2007, 08:13 PM   #6
Home Improvement Guy
ron schenker's Avatar
Is the dog OK?
ron schenker is offline   Reply With Quote
Old 05-05-2007, 05:07 AM   #7
I also had this issue with a wire that was not color coded. however, when i looked at the wire real closely, i noticed that the 2 main ones were either smooth (black/hot) or ridged (white/neutral). I am going to be connecting them this way. Green is of course for the grounding.
Good luck!
Jeanbarb: seems straight forward, except I bought the pigtail with plug (grey) and it has a labeled (center) green with yellow striped ground wire, but each wire on either side, is not color coded black or white, (breaker IS off) How do I know which of the wires each side of the ground wire goes to black and the which one goes to white?
SMERSH009X is offline   Reply With Quote
Old 05-23-2007, 11:52 AM   #8
Rewards Points: 530
Do the straight prongs look the same?
Old 03-05-2012, 04:36 PM   #9
That is correct - Smooth = Hot; Ribbed = Neutral. Green (or Green with yellow)=Ground
(Thought I'd post confirmation since I spent a while trying to confirm the ribbed vs. smooth)
johnbeachfl is offline   Reply With Quote
extension cord draining power? mt232 Electrical 14 05-25-2011 04:37 PM
Ac needs to power cord Buttons50 Electrical 5 07-13-2008 10:58 AM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 03:32 PM
Wall AC power cord options J187 Electrical 2 04-13-2007 05:12 PM
