Removing Stubborn Washing Machine Tub. - Appliances - DIY Chatroom Home Improvement Forum
Old 05-18-2011, 09:01 AM   #1
the Musigician
DangerMouse's Avatar
Removing stubborn Washing machine tub.
any way to repair this washer tub so it spins again? It's totally rusted off the shaft. The wife wanted to screw it to the underside..... I told her if we did that, it'd probably leak all over the place. I was thinking maybe some sort of REAL TOUGH adhesive might get a little more use from it until we can find another used one on CL, but there's a lot of torque on it so JBWeld probably would just break loose again.
DM
Old 05-18-2011, 12:47 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
you are totally screwed, that thing will never wash anything again.
maybe you can talk to a local appliance dealer who disposes of customers old units for them and come up with a used tub, that is very common Whirlpool tub.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 05-18-2011, 01:11 PM   #3
the Musigician
Good idea..... I just tried our best local guy, but even he wants me to bring the whole thing in and still wants around $50.00 for a new tub.
I can get a washer AND dryer on CL for that!
*sigh* It never ends, does it?
Thanks for trying though!
DM
Old 05-19-2011, 01:41 PM   #4
the Musigician
OK, I took out the tub, but now I can't get the broken part off of the main shaft. I can't find any good machines on CL, so it's find a new tub time.
I don't want to break anything, so how the heck does the rest of this thing come off? Is there something under the plastic plugs below? Slip a screwdriver down the slit and make with the secret handshake?
Thanks!
DM
Old 05-19-2011, 06:25 PM   #5
#1 HAWKEYE FAN
take off that big nut on top and it should pull right off
Old 05-19-2011, 07:24 PM   #6
the Musigician
What nut?
DM
Old 05-19-2011, 09:53 PM   #7
#1 HAWKEYE FAN
that big thing with the 4 notches just below the agitator shaft
Old 05-19-2011, 09:59 PM   #8
the Musigician
It don't turn.
DM
Old 05-19-2011, 10:03 PM   #9
the Musigician
Does it need some special tool?
DM
Old 05-19-2011, 10:15 PM   #10
#1 HAWKEYE FAN
yes its called a spanner wrench but I think I've done it before with a pipe wrench
Old 05-20-2011, 08:24 AM   #11
the Musigician
Man, I've been trying all morning, this thing does not move. Well, ok, it MOVES, but the whole mess turns, making it hard to try to wrench them apart. It still looks to me like the center, washer-looking ring would unscrew. I can't seem to find an exploded view/repair manual for it either. We sure need this thing off of there!
DM
Old 05-20-2011, 08:51 AM   #12
the Musigician
Welp, you were right.... it was a large nut. After putting TWO pipe wrenches on it and having the wife hold one to keep it from just turning as I hammered the other wrench, it finally gave.
Now to see if the appliance guy has one. *fingers crossed*
DM
Old 05-22-2011, 09:27 PM   #13
the Musigician
Got it fixed. The used tub was $25.00.
I took the extra time and opened up the dryer and cleaned lint from inside too.
It really needed it!
DM
Old 05-22-2011, 10:01 PM   #14
#1 HAWKEYE FAN
congrats to you DM
Old 05-22-2011, 11:39 PM   #15
Ole Wood Worker
BigJim's Avatar
Rewards Points: 184
DM
Way to go DM, if this had been a year sooner and we were closer we could have given you a good tub, our washer bit the big one but the tub was OK. Sorry you had so much trouble with your washer buddy, glad you got it fixed.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 04:30 AM
Washing machine and dedicated circuit.... ? CoconutPete Electrical 15 11-16-2010 09:02 PM
Removing washing machine drain from septic 12172003A Plumbing 2 07-25-2009 06:32 PM
Tapping water line and drain from sink for washing machine? RyanD Plumbing 2 06-27-2009 09:25 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 12:17 PM
