Removing An Over The Range Microwave - Appliances - DIY Chatroom Home Improvement Forum
Old 07-03-2011, 11:18 AM   #1
removing an over the range microwave
I am trying to remove a GE microwave but cannot get it out because the vent to the roof is holding it. I have a new microwave on the way so I don't want to damage the vent that is there. Help
southcreek is offline   Reply With Quote
Old 07-03-2011, 11:40 AM   #2
Too Old
You should have tape holding the joints of the ducting along with screws , you will have to undo the joints and pull the duct out. The micro will have a rectangular box on top that the ducting ties into, your new micro will have a box with it so don't worry if you bend it, most of the time that box is screwed into the micro before the micro gets mounted.
havalife is offline   Reply With Quote
The Following User Says Thank You to havalife For This Useful Post:
southcreek (07-03-2011)
Removing a Sharp over the range microwave bcbowers Building & Construction 7 11-01-2010 05:10 PM
removing a roper microwave over range? rcarrera Appliances 0 09-09-2010 11:33 AM
OTR Microwave -> Range hood wiring A for Effort Electrical 2 07-31-2010 10:00 AM
Removing over the range microwave from wall mount islic Appliances 8 07-20-2010 02:00 AM
HELP. I really need some advice on how to remove an over the range microwave! justmeee Appliances 9 12-24-2009 03:47 AM
