Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 02-03-2011, 12:24 PM   #1
Removing Motherboard from built-in electric wall oven
How do you remove the motherboard from a GE built-in electric wall oven that is 15 years old?
Lisa Delmore is offline   Reply With Quote
Old 02-03-2011, 04:43 PM   #2
No experience with the motherboards, but do you know it is bad?
Old 02-03-2011, 11:01 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
pull half way out of the opening, remove the top panel. at this time you should be able to see the boards and how to remove them
hardwareman is offline   Reply With Quote
Reuse of 2-wire with ground Type SE cable for 4-wire 240 VAC wall oven chargewrangler Electrical 1 10-20-2010 11:18 AM
Need Advice - Removing Bath Wall Tile Soxckersfc2002 Kitchen & Bath Remodeling 6 02-01-2010 11:49 AM
built under oven as a built in one? helen30 General Discussion 3 01-27-2008 04:15 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Wall oven rusty_5620 Electrical 6 03-15-2007 02:18 AM
