Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 11-28-2009, 01:15 AM   #1
Removing a GE Profile space makerXL 1800 microwave
I am trying to remove my Over the range microwave and i have taken out the bolts in the top but i cannot find the bolts holding the microwave to the back plate in the wall?
cannoncj is offline   Reply With Quote
Old 11-28-2009, 05:00 AM   #2
newer ones just take screws out on top [in cabinet] and tilt forward [rests on lip in back at bottom] really old ones had two screws [located at top behind grille-on either side- that screwed into back plate]
Jacques is offline   Reply With Quote
Old 11-28-2009, 08:12 AM   #3
Man of many hats
wrangler's Avatar
See if this manual helps:
http://products.geappliances.com/Mar...e=49-40538.pdf
Man of many hats
wrangler is offline   Reply With Quote
Old 12-03-2009, 01:52 AM   #4
what you name?
where are you from?
Devis comparatif mutuelle sante |Comparateur mutuelles sante |Comparer comparatif mutuel
Salli1990 is offline   Reply With Quote
Old 12-03-2009, 09:29 AM   #5
Household Handyman
Is this one of the units that has an air exhaust grill over the door? If so, remove the grill and there should be two (2) screws behind the grill which go to the mounting plate on the wall behind the oven. Again, IF it has these screws, be careful when removing them, they hold the oven to the wall. I recommend two people on this: while someone holds the unit, unscrew/remove the long screws, then the two of you lift the oven slightly and remove the unit. Hopefully that's the problem. Good Luck, David
GE Profile Microwave Buzz No HEat crecore Appliances 8 11-09-2012 09:59 AM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Removing a Sharp over the range microwave bcbowers Building & Construction 7 11-01-2010 06:10 PM
Microwave ground prong sparks/melts upon plugging it in microwaveman Electrical 30 05-10-2009 11:30 PM
GE Profile over the Range Microwave BrentH Appliances 5 01-08-2009 11:25 PM
