Removing Dryer Lint - Appliances - DIY Chatroom Home Improvement Forum
Old 01-14-2009, 06:44 PM   #1
Rewards Points: 180
Removing dryer lint
Does anyone know how to take the front off of a front-load dryer? It's made by Whirlpool. I looked in the manual, but it says something like, 'contact a professional'. Three or four years ago I watched a repair man take it apart and thought it looked pretty easy, but I can't remember how he did it.
I'd like to do it soon because he found a chunk of singed lint and other lint near the motor and in other places where it shouldn't have been. I tried the 'As Seen On TV' dryer brush set, but it only does just so much.
Thank you.
gma2rjc is offline   Reply With Quote
Old 01-14-2009, 07:11 PM   #2
I have worked on several older GE dryers and seen others appart. The ones I have done are hinged at the back and have a pair of v shape spring clips pointing down into the side walls of the dryer about 6" back from the front. A flat edge like a good putty knife might help you pop the top. Don't use a large screwdriver as you risk chipping the finish.
Chemist1961 is offline   Reply With Quote
Old 01-14-2009, 07:24 PM   #3
What can I find here?
Winchester's Avatar
Rewards Points: 150
Not sure how similar it is to my year old LG but I had to remove some the top screws in the back. This allowed me to slide the top back and lift off. From there I was able to access the remainder of the screws to loosen the front panel and the screw for the front cover. The bottom of the front cover was slotted and I just had to lift to remove.
Best of luck.
Winchester is offline   Reply With Quote
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
Dryer Pony Problem. Hobb3s Electrical 17 09-30-2008 09:16 PM
New electric dryer is blowing breaker! minameismud Electrical 7 09-14-2008 11:45 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 02:14 PM
Dryer exhaust question Felipon Appliances 6 02-03-2008 12:29 PM
