Remove Mounted Microwave - Appliances - DIY Chatroom Home Improvement Forum
Old 07-02-2010, 03:18 PM   #1
remove mounted microwave
How do I remove a Sharp R-1502 microwave from wall? I've removed the two top screws and bottom screws on the mounting plate.
ezejr2009 is offline   Reply With Quote
Old 07-03-2010, 01:29 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Microwave/vent units also usually have two long bolts (look under front vent cover for bolt heads) that go all the way through the unit back into the wall bracket behind it.
You might need someone to hold and support the unit while you unscrew them to keep it from falling out.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Remove old light fixture (hanging) dj928 Electrical 9 12-02-2009 12:42 PM
Removal of wall mounted kenmore spacemaster microwave staunch12 Appliances 1 11-12-2009 11:03 AM
Over the stove microwave with no vent? monsterbash General DIY Discussions 7 07-17-2009 07:41 PM
Over the stove Microwave or tiling first? MsNotHandy Kitchen & Bath Remodeling 4 06-19-2009 09:20 PM
Remove baseboard heat? Patrick B HVAC 6 04-11-2006 05:12 PM
