Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 12-22-2010, 11:47 AM   #1
A door a day is all I ask
TheDoorGuy's Avatar
Remove GE Oven Door
Hi there,
I have a GE Profile JGS968 gas range. Broiler works....Bake doesn't.
From what I have found noodling around online, my ignitor is probably to blame.
Looks like I need to remove the door to remove the bottom panel to get to ignitor to test it.
I have opened the door to the broil position and tried to lift it up and out but does not feel like it will come out.
Can you folks advise me on how to remove door of my oven? Thanks in advance!
TheDoorGuy
TheDoorGuy is offline   Reply With Quote
Old 12-22-2010, 12:13 PM   #2
TheDoorGuy's Avatar
Remove GE Oven Door
Hi again,
Just found it!....Retaining clips on oven above each hinge had to be pulled down.
Used a flat head screw driver. Hopefully it will go back in easy!
Hello All, oven door stuck k4thdan Appliances 3 11-25-2010 01:58 AM
Remove Door Frame nymlake Remodeling 1 11-05-2010 12:50 AM
How to remove wall oven? brick1930 Appliances 3 12-18-2009 08:50 PM
Swapping exterior door perpetual98 Remodeling 3 11-27-2007 06:55 PM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 09:43 AM
