Refrigerator Turning Off And On - Appliances - DIY Chatroom Home Improvement Forum
Old 01-20-2013, 09:02 PM   #1
Refrigerator turning off and on
I have a Frigidaire FRS26H5ASB9 model side by side fridge. When it wants to turn on, it'll turn on and off, on and off, on and off, (each time being on for a little longer...) until it finally turns on for good. Any ideas what could be causing this? Is it worth calling a repairman? Or should I just replace the fridge? Other than that, it works very well.
mopowers is offline   Reply With Quote
Old 01-20-2013, 09:16 PM   #2
Rewards Points: 12,882
Could be as simple as a starting capistor on the compressor.
Google "repair clinic" there a pretty good website that has DIY trouble shooting and aslo has a place to ask questions, parts break downs and also sell the parts.
Just need your make and model #.
Old 01-21-2013, 09:00 AM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,596
sounds like compressor relay is going bad, get it repaired before it either stops running altogether or does damage to the compressor
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 01-21-2013, 10:35 AM   #4
Is that something a DIYer can do, or only a pro??
Old 01-21-2013, 12:12 PM   #5
I'd call a pro. Sounds like either the compressor is going out or the low press switch is kicking it out. Either way, restarting a compressor quickly against head pressure will end up damaging it. When compressors go bad, they tend to run a little and then the Amps peak resulting in shutdown from thermal kick out. Then it cools and resets and tries again.
64pvolvo1800 is offline   Reply With Quote
Old 01-21-2013, 12:53 PM   #6
Thanks. I'll call someone. Any chance it could just be a control panel going bad??
Old 01-21-2013, 05:22 PM   #7
Always a chance:-)
Old 01-25-2013, 12:53 PM   #8
So, repair man said it's a start relay, which is located in the centralized electronic circuit board. I realize I can't replace just this relay since it's soldered in the small 4" x 4" electronic control box. So, I basically have to replace the whole ECU. They are charging 250 for parts and labor to install it (including the $60 service call). So, they are basically charging me $190 for the ECU with a one year guaranty. Do you guys know where I can buy this part for cheaper and so I can install it myself? It's just a plug and play type of deal located under a service panel in the fridge. I just want to make sure what I buy is a legit piece and not a cheap knockoff.
Old 01-25-2013, 01:18 PM   #9
So, repair clinic has it for $80
http://www.repairclinic.com/PartDeta...918476/1614983
And Amazon has it for $33
http://www.amazon.com/Frigidaire-530...d_sim_sbs_la_2
Looks I'm going to fix it myself and save about $150.
Old 01-27-2013, 07:29 PM   #10
#1 HAWKEYE FAN
either you misunderstood the guy or he does not know what he is doing. The start relay is on the compressor not the board.
Old 01-27-2013, 07:43 PM   #11
He told me there is a different relay for the compressor.
Old 01-27-2013, 07:45 PM   #12
#1 HAWKEYE FAN
try this:Name:  RELAY.jpg
Old 01-27-2013, 07:48 PM   #13
#1 HAWKEYE FAN
yes a compressor relay is the relay I pictured previously. There is no other relay on your refrig.
Old 01-27-2013, 07:49 PM   #14
#1 HAWKEYE FAN
this part is the adaptive defrost control board, it controls your defrost cycle. Nothing else.
Old 01-27-2013, 09:03 PM   #15
Well, there is grinding sound coming from that board. He told me there is a relay on that circuit board that is causing the issue. So, either I can replace it (for $40), or have them come out after wards and do it if it doesn't fix the problem.
