Refrigerator Tripping GFCI - Appliances - DIY Chatroom Home Improvement Forum
Old 12-16-2013, 12:40 PM   #1
Refrigerator tripping GFCI
I have an old kenmore refrigerator in my garage, I think from 98', that instantly trips the GFCI when I plug it in. It has always been plugged in the same receptacle since I've had it and has been working fine for about 9 months with no issues until a few days ago. What is a good starting point to figure out what the issue is? I just so happened to ask for a multi-meter for Christmas...
THANKS
MisterSteve is offline   Reply With Quote
Old 12-16-2013, 01:05 PM   #2
Rewards Points: 2,238
The easy thing to do would be suspect the GFCI -
They do go bad.
What else is on the circuit?
Replace the outlet and see if it happens.
rossfingal is offline   Reply With Quote
Old 12-16-2013, 01:17 PM   #3
Not much really, just a radio and a few strings of lights get turned on in the evening, other than that, only the fridge. I have two separate circuits in the garage and it trips on the other circuit as well. I installed all the wiring in the garage less than two years ago, inspected and all, so I'm pretty sure it's related to the fridge.
Old 12-16-2013, 01:46 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Typically in a fridge that trips a GFCI it is a motor winding going bad or the auto defrost circuit. Neither one worth the cost of repair on a 15 year old box.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 12-16-2013, 01:55 PM   #5
Rewards Points: 13,732
Unplug everything but the fridge to narrow it down.
I'd suspect the outside Christmas lights if it's not the fridge.
Old 12-16-2013, 02:03 PM   #6
A "Handy Husband"
rjniles's Avatar
The poster said that the GFCI trips instantly when he plugs the fridge in and that it also trips the other circuit he plugged into. Pretty much narrows it down to the fridge.
The Following User Says Thank You to rjniles For This Useful Post:
rossfingal (12-16-2013)
GFCI after dimmer switch curiousB Electrical 16 04-08-2013 04:18 PM
Replacing kitchen gfci with gfci breakers-something's not right Fpbaum Electrical 14 05-01-2012 08:43 AM
GFCI - White & Black Both HOT? hagler Electrical 11 03-19-2012 08:29 AM
Can you test a non GFCI plug with a GFCI tester? DIYguy2000 Electrical 3 01-16-2012 06:49 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
