Refrigerator Too Cold - Appliances - DIY Chatroom Home Improvement Forum
Old 11-27-2008, 04:33 PM   #1
Unhappy
Refrigerator too cold
just bought a 2 door (upper/lower) "fridge" from Sears "scratch and dent"
fridge freezes everything solid = can't set the temperature lower
no manual available yet
model 106.42106300
did I get a "2-door freezer" ??
poorguy1 is offline   Reply With Quote
Old 11-27-2008, 06:21 PM   #2
Rewards Points: 2,906
There's a fan behind the freezer compartment that blows cold air BOTH into the fresh food section and the freezer section. This fan typically blows MOST of the cold air into the freezer compartment. However, some models have a baffle that allows you to adjust how much air gets blown where. If you can see any sort of control in your fridge to vary the amount of air going each way, try fiddling with that. If there is no such control, then...
.... you probably got a freezer with a bad thermostat (most commonly called "cold control").
There's probably some sort of warranty on the thing. Maybe phone Sears and explain the problem and they'll send someone out to replace the cold control.
Nestor_Kelebay is offline   Reply With Quote
Old 11-27-2008, 06:47 PM   #3
I looked on the parts website and it says this is a "convertable freezer". You may have to reconfigure something for it to function as a refrigerator.
jerryh3 is offline   Reply With Quote
Old 11-27-2008, 07:19 PM   #4
is this the Gladiator with the diomond plate trim???
sv9779 is offline   Reply With Quote
Old 11-27-2008, 07:58 PM   #5
Yep looks like the Gladiator. That model is a freezer on the bottom (the big section that would normally be the refrigerator section). The top part is also a freezer or it can be made into a refirgerator section. Sooooo if you were looking for a frig to store all you soda they sold you the wrong thing. Only the small top part can be a frig. The large bottom is always a freezer.
Old 11-27-2008, 08:07 PM   #6
Here is the owners manual in PDF form
http://c.sears.com/assets/own/04643173e.pdf
Tags
refrigerator
Hot Water in Cold Water Lines ??? Superbuuck Plumbing 14 08-29-2011 12:21 PM
move cold air return or add extra hot air CamL HVAC 2 03-26-2008 12:43 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 08:05 AM
how cold is too cold for vinyl siding? THEBIGPUNN Building & Construction 1 11-22-2005 10:50 PM
