Refrigerator Is Suddenly Not Cold Enough - Appliances - DIY Chatroom Home Improvement Forum
Old 10-15-2013, 10:07 AM   #1
Rewards Points: 37
Refrigerator is suddenly not cold enough
I have a GE GSL25JFPBS side by side refrigerator. I suddenly have a problem where my refrigerator is not cold enough and my freezer has frost buildup along the back. This happened once before about a month ago, and it seemed to have corrected itself. The problem has returned.
In my refrigerator, things are around 50 degrees. In the freezer, my meat at the bottom of the freezer seems rock hard, but my ice cream at the top of the freezer is soft. I understand that warm air rises and cold air drops, but in the past, I have never had this problem with the ice cream at the top. Both of my dials for the freezer and refrigerator were set to 5 on a scale of 1-warmest to 9-coldest
A week or two ago, I went food shopping and had the freezer packed pretty tight with food. I am wondering if an airflow issue initiated the problem. Last night, I pulled some food out and saw the orange glow of the defroster running, so I know that the defroster coils turn on. I moved some things around to help the air flow. I turned the knobs to 7 to increase the coldness last night, but things were not any better this morning.
ed3120 is offline   Reply With Quote
Old 10-15-2013, 10:21 AM   #2
Rewards Points: 13,260
Circulator fan running?
http://www.repairclinic.com/RepairHe...roubleshooting
Old 10-15-2013, 10:25 AM   #3
Rewards Points: 37
I hear the refrigerator making the standard refrigerator noises, so I assumed the compressor and the fan were working, but I get it's possible that I'm only hearing the compressor. I'll have to listen again when I get home. In a simple refrigerator like this, is there typically just one fan, or a separate one for the refrigerator and freezer? I know the refrigerator air comes through a vent in the top left, towards the back. Should I just put my hand there and feel for an airflow? Would it typically be a strong airflow, or would it be hard to notice?
Old 10-15-2013, 10:44 AM   #4
Rewards Points: 37
Just another piece of information...I had lettuce in my crisper (bottom drawer of refrigerator) freeze completely last week. I thought that was odd, so I turn down the dial on the crisper.
Old 10-15-2013, 10:50 AM   #5
747
registered
747's Avatar
Rewards Points: 534
could be the thermostat sensor
747 is offline   Reply With Quote
Old 10-15-2013, 11:26 AM   #6
Rewards Points: 690
If removing items away from the freezer to fridge air flow vent doesn't solve the problem, move sensitive foods to another suitable location and manually defrost for a few hours. I had a air flow vent control freeze because of leaving the door open too long while replacing a door gasket. My daughter recently had the same problem and a manual defrost over night solved the issue.
Old 10-15-2013, 11:32 AM   #7
Rewards Points: 37
That's interesting actually, because every now and then, my door water dispenser line freezes up. The solution is to leave the door open for about 90 minutes and it unfreezes. I did that about a month ago. I wonder if I caused something to freeze up by having the door open for so long.
Old 10-17-2013, 07:05 PM   #8
biggles's Avatar
check the condenser coils under the frig is it covered in dust and the blade on the fan that blows air over it?keeping the freezer 3/4 full with space on the top is the norm the ice build up within actually insulats the top coil and the frig part suffers with the temp you see
Old 10-21-2013, 09:32 AM   #9
Rewards Points: 37
SOLVED:
I removed the food, and took off the back panel inside the freezer to reveal the defroster coils. They were completely encased in ice. I defrosted them with a hair dryer, put it all back together, and it's been working without issue for several days. Both the refrigerator and freezer sides are now back to their normal temperatures.
I believe the ice build up problem started when I left the door open for about 90 minutes.
Thanks for the helpful suggestions.
Old 10-21-2013, 11:44 AM   #10
Rewards Points: 690
Originally Posted by ed3120 View Post
SOLVED:
Good for you.
It makes one wonder how many appliances of all kinds are dumped annually for a for a new unit because of often minor deficiencies.
Cold air returns, or transfer ducts/grills? bobgodd HVAC 15 01-01-2013 08:57 PM
Freezing storage room next to the cold room Van3 Building & Construction 2 01-23-2011 06:50 PM
Cold Air from Ceiling Vent and Bathroom Fan thehendrix HVAC 0 01-13-2011 11:31 PM
Backdraft, Cold Air and Ice from Range Hood and Bath Fan Passion4Heels HVAC 13 08-19-2010 08:00 PM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 11:29 AM
