Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 11-18-2011, 10:33 AM   #1
Refrigerator not cooling enough
Our 10 yr old Kenmore fridge isnt cooling enough. We tried to change the setting and we waited 24 hrs, but its the same. What can we check? We are ready to sell it, but we don't want to sell it in this condition.
dinosaur1 is offline   Reply With Quote
Old 11-18-2011, 04:40 PM   #2
I'm Your Huckleberry
If you have a refrigerant leak which I'm almost certain you do than you're going to have to call a refrigeration company out to charge it. More than likely you're going to have to call out a company to diagnose the problem to begin with and at ten years old I'd suspect it's not worth the money.
Let the local skateboarding kids have it, they'll put it to good use.
Doc Holliday is offline   Reply With Quote
Old 11-18-2011, 05:08 PM   #3
What can I check to see if its that or soemething else before calling anyone?
Old 11-18-2011, 05:38 PM   #4
You'll need a meter to test amp draw on the compressor to see if it's running as it should and you'll need refrigerant gauges (specific to what refrigerant your fridge uses such as the possible 134) and hope you have service ports to connect to.
It's really not all that easy to simply just check without the correct tools.
Old 11-18-2011, 05:43 PM   #5
I shut off the unit from the inside. It turns off so fans are working ok. Now it's just a matter of testing it properly.
Old 11-18-2011, 06:05 PM   #6
biggles's Avatar
if you have the condenser on the bottom with a fan running might need brushing out is it just the refrig section and or the freezer also... does the compressor run
Old 11-18-2011, 06:26 PM   #7
Mainly the refrig section.
Old 11-18-2011, 06:30 PM   #8
Here are some pics.
Refrigerator not cooling enough-image-4244409551.jpg   Refrigerator not cooling enough-image-3766181073.jpg
Old 11-18-2011, 06:35 PM   #9
#1 HAWKEYE FAN
hardwareman's Avatar
first things first,
1) check the evap coil for frost build up
2) check the condenser coil for lint and what not
If your freezer temp is ok then I quarantee it is not a freon problem, most likely a defrost problem
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 11-18-2011, 07:07 PM   #10
Originally Posted by hardwareman
first things first,
Looks pretty dusty in there.
Old 11-18-2011, 08:33 PM   #11
first things first,
Coils located in the front we're very dusty. Got it cleaned out. It takes 24 hrs for the temp to balance out so ill let you know shortly.
Old 11-18-2011, 08:45 PM   #12
biggles's Avatar
even the fan blades if they are dusty...how's the freezer setting?the refrig works a damper door that closes when the box reaches.temp i have a GE about that old initial on the freezer is C and the refrig section is 5....let it run over night...hows the freezer box not packed up....clear the dischrge grills of stuff... for the run
Old 11-18-2011, 10:24 PM   #13
I have to wait 24 hrs for the temps to adjust and ill report back.
Old 11-18-2011, 10:31 PM   #14
biggles's Avatar
in the morning should be stable
Old 11-18-2011, 10:47 PM   #15
Thanks ill let u know.
Cooling capacity relation with air temperature. Samart HVAC 2 06-23-2011 08:39 PM
Help! Just changed my Fan Controler (ICM 275) now system "false starts" when cooling redmachodevil HVAC 4 01-26-2011 04:21 AM
Wiring a Ruud RGTK-06E series furnace for 2-ton cooling bolo_invictus HVAC 3 01-25-2010 04:24 PM
Installation of Honeywell Thermostat - cooling function KDW Electrical 0 10-04-2009 10:56 AM
kenmore 596.58695890 cooling issues mindraven Appliances 7 08-22-2009 09:00 AM
