Refrigerator Not Cooling Correctly - Appliances - DIY Chatroom Home Improvement Forum
Old 01-04-2012, 11:30 AM   #1
refrigerator not cooling correctly
kenmore refrigerator model 253.61662101...refrigerator not cooling well enough....fan is working and blowing air from freezer but it just does not seem to be cold enough....also up until about 5 days ago water was settling on top shelf of refrigerator where fan blows cold air but that stopped, I don't know if that means anything or not....gasket around door is clean and working fine, refrigerator is sitting level..
mrswow is offline   Reply With Quote
Old 01-04-2012, 12:25 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,586
freezer freezing? what is the temp in freezer?
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 01-04-2012, 02:01 PM   #3
Everything in freezer is frozen as should be but I don't know the temp.
Old 01-04-2012, 08:10 PM   #4
#1 HAWKEYE FAN
if the freezer temp is adequate ( yet to be determined) and not enough cool, then you will have an airflow problem. You will have to take the back panel off the evaporator coil and look for either a heavy frost build up or your air damper iced up.
Old 01-05-2012, 10:36 PM   #5
Another quick step you can do is open the fridge door and put your hand on the vents where the cold air enters . Do you feel and air flow? Yes? Check to see if your condenser coils are free of dirt ,lint ect. If NO(you do NOT feel air flow) than you might have a defrost problem and you will need to look at your evaporator coil which will be located if freezer section behind the back panel as discussed by ''hardwareman''.
acestarservices is offline   Reply With Quote
Cooling capacity relation with air temperature. Samart HVAC 2 06-23-2011 08:39 PM
Help! Just changed my Fan Controler (ICM 275) now system "false starts" when cooling redmachodevil HVAC 4 01-26-2011 04:21 AM
kenmore fridge/freezer not cooling dmcculley Appliances 0 07-10-2010 11:47 AM
Wiring a Ruud RGTK-06E series furnace for 2-ton cooling bolo_invictus HVAC 3 01-25-2010 04:24 PM
Installation of Honeywell Thermostat - cooling function KDW Electrical 0 10-04-2009 10:56 AM
