Refrigerator Icemaker No Power - Appliances - DIY Chatroom Home Improvement Forum
Old 02-05-2010, 01:15 PM   #1
refrigerator Icemaker no power
I have a Kitchen-aid KSSS48qjw00
I understand that it is real similiar to whirlpool refrigerators.
The icemaker is not working. I test the power between L-N and there is no voltage at all. I remove the icemaker and test the connector and still no power. What do I need to test next?
pcrtx is offline   Reply With Quote
Old 02-06-2010, 06:24 AM   #2
on the frz wall side did you check where black and white would go>120vac. if ok I/M bad, also that harness has a line fuse in it that may have popped. I/M comes with new harness. if not, this gets techie, you should call local servicer.
Jacques is offline   Reply With Quote
house power supply upgrade in Australia pcd1965 Electrical 3 08-22-2009 08:17 PM
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 06:15 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
