Refrigerator Ice Maker Problem - Appliances - DIY Chatroom Home Improvement Forum
Old 08-19-2006, 07:42 AM   #1
Refrigerator ice maker problem
Model - KichenAid KSRS251KWH03. 6 years old. It's a side by side, when it is making ice cubes, there a motor noise and it sounds like it's working extra hard..almost a grinding sound, but it does make ice. the water dispenser flows very slowly (I don't get water from the refreigerator anymore). This noise goes on daily.
Does anyone know what this noise is? It's been going on for about 9 months now. The refriegerator stays cold 40 degrees and the freezer seems to be okay too
apt238 is offline   Reply With Quote
Old 08-19-2006, 07:54 AM   #2
Have you changed the water filter that supplies water to the refrigerator (dispenser and the ice maker)?
redline is offline   Reply With Quote
Old 08-19-2006, 02:09 PM   #3
Sounds like a filter and/or supply line problem. Go with the new filter first since they only run about $30-35 and are easy to replace.
BigFloyd is offline   Reply With Quote
Old 08-19-2006, 02:49 PM   #4
jeff1's Avatar
Hi,
Nope since we cannot hear it for ourselves.
Fill valve buzzzzzing from low water pressure??
Think the noise is more inside the refrigerator or outside of the refrigerator?
Poor/low pressure fills...clogged shut off valve ( esp self piercing style ), bad fill valve, tired filter, kinked line.
jeff.
Appliance Repair Aid
www.applianceaid.com
JRAppliance
www.jrappliance.ca
jeff1 is offline   Reply With Quote
Old 08-19-2006, 03:59 PM   #5
Yes, I did change the filter. But, the noise never went away. I was thinking that it was a problem with the supply water, but not sure bc of the noise. It sounds like it's working extra hard.
Thanks for any helpful tips on this.
Old 08-19-2006, 04:36 PM   #6
If you had to move the refrigerator to change the filter then you may have kinked the small water supply line behind the fridge. Whne you moved it back.
Old 08-19-2006, 05:45 PM   #7
refrigerator ice maker problem
I did check the water line, but didn't notice any kink (it's been a while). I'll double check again.
I curious about what the cause of the motor noise could be.
Thanks for all the good tips,
Old 08-19-2006, 05:48 PM   #8
Did you check to see if an ice cube has become logged in the unit?
Old 08-19-2006, 07:20 PM   #9
thank you, I'll check and see if there is a ice cube stuck in the tray where the water fills it.
Old 08-20-2006, 08:11 AM   #10
jeff1's Avatar
Think the noise is more noticable inside the refrigerator or outside of the refrigerator?
jeff.
JRAppliance
www.jrappliance.ca
Old 08-21-2006, 10:08 PM   #11
no ice cube found stuck anywhere in the ice maker inside the freezer.
the noise sounds like it's coming from inside.
Old 08-21-2006, 10:41 PM   #12
jeff1's Avatar
KSRS251KWH03
Likely KSRS25IKWH03
The module assy ( icemaker head ) has a motor on it. The noise could be comming from that?!...
Icemaker control module and motor assembly
The plastic front cover comes off for a better listen when you hear the noise.
jeff.
JRAppliance
www.jrappliance.ca
Old 08-22-2006, 09:52 PM   #13
that is a good possibility that the noise is from the ice maker head. Next time, I hear the noise get up and listen to the door or I'll open the freezer and hope to hear it that way.
Old 08-24-2006, 10:22 AM   #14
Commercial Flat Roofing
This is a strange thing.
Mine groans, rather annoying. It happens when an ice cube gets stuck during the dump of the cubes.
One of the separators was damaged a while ago and every once in a while it starts to moan, groan, creak etc I have to pull a cube out and the noise goes away.
Talos4 is offline   Reply With Quote
Old 08-24-2006, 11:37 AM   #15
Sometimes mildew can build up in a line impeding flow, especially where the line is made of plastic.
cambece is offline   Reply With Quote
Ice Maker Not Getting Water sgorak General DIY Discussions 3 10-27-2008 08:02 PM
HELP - No Water to Ice Maker noice Appliances 13 07-17-2007 09:41 AM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
Water Delivery Problem amadis Appliances 6 12-20-2006 10:22 PM
