-   -   Refrigerator ice maker problem (http://www.diychatroom.com/f47/refrigerator-ice-maker-problem-3863/)
apt238 08-19-2006 07:42 AM
Model - KichenAid KSRS251KWH03. 6 years old. It's a side by side, when it is making ice cubes, there a motor noise and it sounds like it's working extra hard..almost a grinding sound, but it does make ice. the water dispenser flows very slowly (I don't get water from the refreigerator anymore). This noise goes on daily.:(
Does anyone know what this noise is? It's been going on for about 9 months now. The refriegerator stays cold 40 degrees and the freezer seems to be okay too
redline 08-19-2006 07:54 AM
Have you changed the water filter that supplies water to the refrigerator (dispenser and the ice maker)?
:thumbup:
BigFloyd 08-19-2006 02:09 PM
Sounds like a filter and/or supply line problem. Go with the new filter first since they only run about $30-35 and are easy to replace.
jeff1 08-19-2006 02:49 PM
Hi,
Nope since we cannot hear it for ourselves.
Fill valve buzzzzzing from low water pressure??
Think the noise is more inside the refrigerator or outside of the refrigerator?
Poor/low pressure fills...clogged shut off valve ( esp self piercing style ), bad fill valve, tired filter, kinked line.
jeff.
apt238 08-19-2006 03:59 PM
Yes, I did change the filter. But, the noise never went away. I was thinking that it was a problem with the supply water, but not sure bc of the noise. It sounds like it's working extra hard.
Thanks for any helpful tips on this.
redline 08-19-2006 04:36 PM
If you had to move the refrigerator to change the filter then you may have kinked the small water supply line behind the fridge. Whne you moved it back.
:thumbup:
apt238 08-19-2006 05:45 PM
refrigerator ice maker problem
I did check the water line, but didn't notice any kink (it's been a while). I'll double check again.
I curious about what the cause of the motor noise could be.
Thanks for all the good tips,
redline 08-19-2006 05:48 PM
Did you check to see if an ice cube has become logged in the unit?
apt238 08-19-2006 07:20 PM
thank you, I'll check and see if there is a ice cube stuck in the tray where the water fills it.
jeff1 08-20-2006 08:11 AM
Think the noise is more noticable inside the refrigerator or outside of the refrigerator?
jeff.
apt238 08-21-2006 10:08 PM
no ice cube found stuck anywhere in the ice maker inside the freezer.
the noise sounds like it's coming from inside.
jeff1 08-21-2006 10:41 PM
KSRS251KWH03
Likely KSRS25IKWH03
The module assy ( icemaker head ) has a motor on it. The noise could be comming from that?!...
http://www.repairclinic.com/dbimages...0/00202925.jpg
Icemaker control module and motor assembly
The plastic front cover comes off for a better listen when you hear the noise.
jeff.
apt238 08-22-2006 09:52 PM
that is a good possibility that the noise is from the ice maker head. Next time, I hear the noise get up and listen to the door or I'll open the freezer and hope to hear it that way.
Talos4 08-24-2006 10:22 AM
This is a strange thing.
Mine groans, rather annoying. It happens when an ice cube gets stuck during the dump of the cubes.
One of the separators was damaged a while ago and every once in a while it starts to moan, groan, creak etc I have to pull a cube out and the noise goes away.
cambece 08-24-2006 11:37 AM
Sometimes mildew can build up in a line impeding flow, especially where the line is made of plastic.
